    Inlet Manifold coked up!
    Hi All,
    Just had the throttle body replaced as the butterfly had seized up.
    Whilst doing it, dpf guy pointed out that the manifold inlet was chocka with soot and should be cleaned out!
    On speaking to a local LR engineer he said they are all like that and best not to touch!
    Having a look at the new throttle body (two weeks old), it is filthy inside with soot.
    What everyone's thoughts on it, clean out the manifold inlet or leave it be?
    Phil
    That's the inlet on the left of the throttle body, from the front
    It's a td6, one turbo and egr.
    I'm a Pratt, I meant the inlet on the right, not the left!
    I don't overly fuss about a bit of soot or carbon build up unless it's excessive or clogs the boost sensor at the back of the throttle body... or makes the butterfly valve in the throttle body stick. You'll know if that happens though as it'll cause a turbo overboost fault and the car will go into limp mode, sometimes with a 'DPF full' as well as the turbo overboost message on the dash.
    The soot and carbon build up in the inlet manifold is an unfortunate (but deliberate) consequence of the EGR's fitted to modern diesel engines as manufacturers forever chase politically driven, stricter emission controls Neutral
    All those emission control systems, specifically EGR's, have the same effect on diesel engines as sticking a rubber hose up your ar*e, shoving the other end in your mouth, then running around all day breathing in the fumes...
    Thanks Mole,
    That's what caused me to replace the throttle body, stuck butterfly and over boost message.
    Now I'm wondering if that will happen again quite quickly as I haven't dealt with what caused the problem.
    The bus has done 60,000 and I'm guessing it's the first throttle body replacement.
    What do you think. Leave it alone or have a go at clearing some of the soot?
    Phil
    I'd leave it be if you've replaced the throttle body to be fair, certainly at that low mileage. The throttle body is easily cleaned though if you remove it and spray it with brake cleaner (or the expensive alternative of a branded carbon cleaner).
    In the mouth of the inlet manifold itself, you have to be careful when cleaning as you don't want any lumps of hard carbon falling off and down to the turbo or EGR. You can carefully pull or wipe out as much as you can...but never just spray it with cleaning fluid and wash it inward down the manifold Thumbs Up
    How about removing the throttle body and setting about inlet with an old vacuum cleaner, do you think that might be effective without causing any damage?
    Yup, the Henry hoover is a mechanic's best friend in that case, they're great for sucking up damp soot or carbon deposits without blowing up. Don't go using the wife's posh Dyson though, starvation, radio silence and celibacy don't go well together...Ask me how I know that and why I've now got a yellow Henry hoover in the garage Laughing
    As for the root causes of excessive soot or carbon build up...short distance stop/start town driving is a common culprit. Turn your auto stop/start off unless you feel it's necessary...your engine will thank you in the end. Once a week, go for a blast up a motorway or decent A roads for a bit to get the turbo working and put the engine under a bit of load at higher RPM Wink
    Thanks Mole,
    I'll get on it next week and let you know how it goes.
    Phil
  • Lynchyy
    2020 Discovery SDV6 First Edition Loire Blue
    Can you do this permanently?
    Yes, if you have a GAP IID tool. There's a setting that is something like "retain last user setting," which will automatically start the car in the last configuration for things like auto start-stop.
    Another method is to get on the motorway, hang out in the slow lane in manual mode with the gear selector in a lower gear that keeps the RPM above about 3,000, and drive it like that for at least 20.minutes. The heat generated will generally burn off the soot and clean the DPF.
    It's a relatively straight forward DIY process...but like DieselRanger said... only if you have a gen 4 GAP IID tool and are confident enough to go messing around in your D5's Car Configuration Files.
    I posted a step by step How-To in the Tips and Tricks section on here a few months ago detailing the process after I had edited and enabled the Auto stop/start user memory function CCF on the Bling Barge...
    All the CCF edit does is enable the Last User memory mode that's already available but hidden away in the CCF's. The auto Stop/Start is set as enabled by default due to JLR conforming to current Euro6 emission regulations on the earlier pre-hybrid TD6 and SDV6 diesel engines, but the option to set the button memory mode is there if you have an IID tool and know where to look for it.
    As to why Land Rover didn't add the option to enable the already included button memory mode in one of the onboard menu systems...your guess is as good as mine. Rolling Eyes
    One of the most commonly asked questions by TD6 and SDV6 engined D5 owners who find the auto Stop/Start function being permantly on by default as irritating as I did, is how to turn it off...so I plugged in my IID tool and sorted it.
    Unfortunately, tackling advanced options...editing CCF files specifically... alongside more basic and essential tasks of diagnosing and resetting DTC faults, calibrating suspension heights and many, many servicing and maintenance related functions on a D5... usually means forking out for one of the most powerful Land Rover specific and VIN locked OBD2 diagnostic tools from Gap Diagnostics in Canada...which are eye wateringly expensive. Neutral
    There are other generic mid range diagnostic tools that offer a fairly good coverage of D5 service and maintenance functions like the iCarsoft CRMax...but editing CCF's is solely the realm of the IID Tool outside of official LR dealership software.
    The IID tool doesn't cover the latest 2026 models... But I really can't imagine the proud owners of a shiny new '26 plate Land Rover will be reaching for the spanners quite yet. Laughing
    Apologies for the long winded reply stacked with rambling off-topic page fillers...I'm bored and stuck indoors lounging around in front of my PC in the Mole Cave due to the weather. Neutral
    TLDR is...You'd need an IID tool to do it properly. Whilst there are other, slightly cruder methods of disabling the auto stop/start... like pulling the plug in the battery compartment and disconnecting it, but that totally disables the stop/start system until you plug it back in, not to mention throwing up a few unrecoverable DTC faults when the car is plugged into any diagnostic software. Pulling the plug out may also effect functions like the Battery Monitoring System...possibly others.
    It's never a bright idea to go deliberately adding DTC faults to a Land Rover in my book.
