Hi Craig car was registered on March 31 St mate. Just beat the VED by the skin of its teeth. Yes any sweetners I will PM you. Well best of luck with yours today and post some photos up
Ha ha I was wondering what you were on about. Mind you the D5 does look quite similar too the RRS from the front.
Well I have a 4 digit and a 5 digit plate, so depends which ones going onto the car in a few months time, provided that I still have it. Also plates are both shortened, so will put photos up once they have been put on in September..
With regards too the tow bar it's sitting too low so going up 1 notch or possibly 2, and adding a 50 mm spacer block onto it also. Will post photos once done.
I also asked for the original tow eye cover too be given back too me which they did along with original roof fittings and grommets.
