    LISTEN for the Windscreen leak!
    Ok I have yet to fix the leak but I believe I know where it actually is.
    After overnight rain I went to the car that had been prepped with kitchen towel wedges in every suspected nook and cranny. Including around the now dried out carpets mentioned on another thread.
    The only damp paper was hanging from the head trim right in front of my eyeline.
    I poured some water into the ‘gutter’ generated by the glass and the rubber and watched the bead very slowly drop preferentially, about a foot inboard ……approx in-line with my soggy tissue observation.
    So I started thumping gently the top of the windscreen glass with the heel of my hand.
    LISTEN to the attached video…
    [url] ?si=uNCoT4q1z-xRS0Y7 [/url]
    (Appologies for the quality I am no Steven Spielberg**)
    Also notice at the end of it, I created a bubble in the gutter and squeezed out some droplets onto the inside of the windscreen in the same position as the noise change and soggy tissue.
    Methinks I’ve found the exact leak point….now can I seal it????]
    Time for …..Captain Tolley’s Creeping Crack Cure.
    ** Those eagle eyed will no doubt spot the presence of the telltale droplets before I started thumping.
    This was my “take2” ….after I fell off the ladder swearing profanely the first time I did it. That video was too funny and foul mouthed to grace this forum. Whistle
    Your clever technique for finding the gap in the sealant would have been worth all the swearing, I'm remembering it in case my windscreen ever has a leak Thumbs Up
    Let's hope Cap'n Tolley with his one leg and a case of the creeping cracks can cure it Whistle
    Update….after dousing with Captain Tolleys Creeping Crack Cure the ‘sound’ on the windscreen has changed ….my thump is now a consistent tone across the screen. Is it too soon to be optimistic?
    Waiting (nervously) for a downpour having removed all external shelter.
    Looking forward to driving my Discovery, without a towel across my lap. Wink
    Great work "Wolfie".
    Don't be surprised if you need to dose with Tolleys a few times, if the cracks are too big, a number of applications can be required.
    Phil
  • Chalkey
    I’m on my 2 Discovery and 3rd leak it’s a joke, we need to get a group action together. Land Rover have known about the problem for 10 years and haven’t sorted it. Land Rover has issued a Technical Service Bulletin (3) to address the problem by having dealerships inspect and, if necessary, replace the windshield free of charge under the Service Action N221 program. Which to me admits there’s a problem
    Phil
    Thanks for introducing him to me. Thumbs Up
    Yes I’ve done 2 applications already…but prepared to keep doing it if necessary,
    It’s clear this leak is different to the deluge one I had 3 years ago that necessitated the screen refitting.
    This is a seep, which puddles over time in the edge of the head lining and then drips with car movement ….onto my trousers Big Cry
    It tends to be worse after sustained drizzle rather than a short sharp downpour…suggesting it is a sloooow ingress like a small hole. The video also supports this, as my thumping produced a small water bead in one location of the rubber seal. It makes me wonder if this time it is just an 8 year old rubber seal damage/failure?
    I am not convinced there isn’t a fundamental design fault in the roof shape/contour at the windscreen interface. Looking closely, as I have done recently, on my vehicle the windscreen doesn’t follow the roof line as faithfully as I would have expected, requiring much thicker sealant in some areas to bridge the gap.
    ( it is the original factory fitted windscreen by the way, that was reseated after leaking 3 years ago)
    Does the Defender suffer from this issue?
    Rather than a design fault...although I've never liked the fad for gluing windscreens on rather than fitted in a rubber seal... I'd more suggest that's it's an assembly line flaw where the seal is applied from bottom up leaving the gap (however small) at the top of the screen rather than the bottom.
    Over time, the sealant will degrade or come unstuck, especially with heated screens. With the gap being at the top edge, it'll be more prone to leaks. It seems that the Discovery has suffered more than other brands in this area. JLR are obviously aware of this fault in the assembly line process and have been for some time...hence the recall or free replacement screens for some affected.
    It's only the Discovery 5 that seems prone to it... as far as I know...but it happens on all models since the D5 was introduced...and not all of the models/variants for any particular year of manufacture have the problem so it's difficult to pin to a particular model or year...very strange how it only effects 1 in a few thousand...bad batch of glue, change of windscreen installation methods or a lack of sealant applied in one or more assembly plants?
    Who knows? Neutral
  • benip
    2020 Discovery SDV6 HSE Lux Carpathian Grey
    I found this thread the other day and am following with interest now. I have an occasional leak on both sides of the windscreen. Sometimes one side, sometimes the other, sometimes a drip and usually a bead that runs down the windscreen.
    I've tapped as per the video and have a hollow sound above each sunvisor. I've ordered some Capt Tolley's and will see what happens.
    Old Cap'n Tolley will be wondering what the hell is happening with a rush on recent sales...I don't have a leaky windscreen in the Bling Barge (yet)...but it certainly sorted out a nasty little crack in the edge of the plastic shower base in the downstairs bathroom Laughing
  • Chalkey
    I’ve been told by a windscreen fitter that the wire for the heated windscreen goes through the adhesive which compromises the bond. Not sure if that’s true, he told me other manufacturers the wire is below the glue?
    I’ve was informed by Hatfields Land Rover A1 windscreens are fixing my windscreen JLR must be fixing it as a gesture of good will because I’m not paying for it.
    Who knows? Neutral
    But how come they leak again, after auto glass, National windscreens et al refit them ‘properly’?
    Mine lasted 3years after they refitted it…..there must be something else that’s causing the repeat problem?
    Oh and by the way …I bet I haven’t used my front heated screen more than 4 or 5 times in the 6 years I’ve owned the car…so I cannot believe it’s that wiring compromising the sealing.
  • Chalkey
    Yes you might be right it could be a design fault my first Discovery had a leak which was repaired and started leaking again after 2 years.
