- discopete
How to fit roof bars or cross bars
My D5 has factory fit roof rails and I want to fit original roof bars (VPLRR0154) but cannot figure out what the various levers are for. I have watched youtube, searched on this site and others and whilst there are some videos showing bits of the process none seems to cover the levers or how to remove the bars without brute force. The clamping mechanism seems to be slightly sprung so stays wide when positioned over the rail. The pin is then located into the rail and the bolt is tightened using the allen key just like countless other bars for other cars. So what is the purpose of the black handle and the red plastic locking device? It doesn't seem to do anything! When removing the bars presumably just undoing the bolt should be enough, Does the clamping mechanism spring open or does it require a lot of force? I am normally pretty mechanically minded but this has me stumped!
- Mole HD
You're not the only one...having precariously balanced on a box and fitted a set myself I had to search around the internet for some virtual assistance in working out what all the knobs, screws and levers actually did.
I found this vid from a kinda straight up Aussie guy helped me suss it out in the end.
Hope it helps
To remove the bars...unscewing the torx bolt on the end under the cap fully will let you remove them with no effort. You have to drop the red lever to get access to the bolt...it's the one you use to tighten them onto the roof rails. The bars won't come off until the torx screw is loosened
- discopete
Thank you for that. I had seen that video but he doesn't explain or use the black handle and red lock. When he has finished with the torx he then closes the cover but doesn't touch the handle or red cover. I can see how the torx holds and releases the bar but I can't see the purpose of the handle and red cover. Also when the torx is undone do the clamp jaws spring open or do they have to be prised apart?
- Mole HD
Once you pull down on the red locking lever to gain access to that torx bolt (the one that goes click when you tighten it), undoing the bolt fully will push the clamps apart so the bars just lift off the roof.
I removed mine the other week...took me a few head scratching minutes to work out how to get them off since they've been on for a year. It's all down to that torx bolt...the bars won't come off until those bolts have been fully unscrewed at both ends of the roof bar....
I still haven't worked what all the levers and handles are all about either...absolutely nuts as a design
- Narpy
I was exactly the same, the mechanism with the red handle just didn’t make any sense to me in fact, it seemed to get in the way and constantly covered up the very thing I needed access to.
The only advice I can offer, is slacken everything off initially, position your roof bars, then attempt to tighten everything using the Allen key and torx bit.
Getting that “pip” to align brought me a world of pain I never knew existed.
Hopeless invention with zero instructions on how it should work.
