- Ecosse
Fuel filler flap lock
Recall seeing a thread about some cars not having a locking fuel flap - does anyone know if the wiring/connector is behind the fuel filler assembly (apparently on some Defenders it is) in which case can this be resolved (and risk of fuel theft/contamination avoided) by having the missing motor/solenoid latch installed (there is a video on line of this being done on a Defender!)....or is that an overly simple solution?!
- BBDisco5
- Ecosse
Thanks, looks like a workaround.
Waiting to check car, but can you confirm if the filler surround casing on yours has a hole where the solenoid pin would pop through to lock the filler flap latch?, as if so it may be a simple job to instal the solenoid provided the wiring is there which it is likely to be if it was just a parts shortage causing the solenoid to be omitted!
- BBDisco5
If only !
Car has been in the dealers for the past 2 weeks waiting for carpets after the windscreen leak and replacement.
- Wolfpack
- Mole HD
Yeah, I was briefly stationed at Catterick during the fuel crisis...all of us that had HGV's with a haz-chem certificate got dragged in to driving relief tankers to fuel stations up and down the country...
During the mid to late 70's and the infamous winter of discontent...I covered the bin lorry drivers strike, the ambulance drivers strike, the tanker drivers strike (twice) and the firemans strike...
The British army...never really wanted in government budgets, but always way too handy when civilisation breaks down for a few weeks
