  • PPiper
    Drain holes on a panoramic sunroof?
    I have a 20plate Disco Landmark and I'm getting water in the cabin.
    I've looked at the door and tailgate seals and all seems good, there is no water in the doors. It was mostly in the front floorwell and there was a lot in the foot rails.
    Searching it seems the sunroof drain can be a common cause but mine is a panoramic one.
    I was wondering if it has a drain as I can't see why it would need one, but if it does can anyone point me to where can find it. I don't want to start pulling trim off uncesseserily.
    I used the aqua vac to dry it out as best I could and got about 10lt that way and I've now got a heater in there with a dehumidifyer. I expect it will take some time to dry properly but it's useless unless I can cure the fault. Any advice would be appriciated, TIA
    Is the headliner wet?
    What makes you so sure it’s the roof leaking and not the windscreen? A significant number of water in the footwell start with the dreaded JLR windscreen plague.
    Unless I'm mistaken fixed panos dont have a drain? I may be wring.
    On old RR405’s with opening roofs the point at which the drain tube connected to the sun roof cassette rotted leading to water igress but this was normally under the rear of the front seats. Both sides had a drain tube running down the D posts.
    That much water may well be leaking windscreen seal. I understand this starts at the top middle area.
  • PPiper
    Thanks for getting back
    @ Wolfpack. I can't be sure its not the windscreen but I read somewhere that you can test for some play in it and you'll see some movement if the seal has gone. I gave that a wiggle and it's rock solid. Also took the A beam external panals off, there was a bit of grime in the drain channels but no obvious sign of leak. The dash is dry and interal A beam trim is also dry.
    @ajac. No sign of water on the internal trim but its leather so I'm not sure not long that would take to show.
    I was thinking I might be able to sort a blocked drain but I can't do a windscreen. I believe the top side trims just lift off, so I'll get some heat on those to lift them and have a look. After that it's a call to Autoglass.
    I'll let you know what I find.
    Having spent the last few months trying to understand my windscreen leak I can categorically say it’s a complex issue that cannot be diagnosed with a quick flex.
    At the risk of boring others silly, there are two issues that result in windscreen leaks.
    The seal to which the windscreen is bonded and the rubber ‘roofline-windscreen” trim.
    I have a leak that ‘finds its way’ to the headliner behind the drivers sunvisor. To get there, water has to get past BOTH these supposed seals.
    The lower ‘bonding’ seal can only be accessed with the windscreen removed. See photo.
    However I have to ask…how come water is getting past the roofline rubber seal into this space between?
    Looking at this area it doesn’t seem like a natural “designed” drain route for rain! It seems to me that water shouldn’t really get there, past the roofline rubber seal.
    Photo . With roofline seal missing …….showing how water must get past it anywhere along its length to get to the lower seal gap.
    Stuff some kitchen towel up between the windscreen and the headliner during the next rainstorm if you want to rule it out!
  • Voyager
    Are you sure its not the aircon drain?
    I spent some time hunting down the cause of a wet drivers floor.
    round the windscreen, sunroof and headlining etc.
    I finally removed the drivers side carpet. (seat unbolted and trims around the drivers pedal area)
    it was immediately obvious the the drain had never been properly fitted into the side of the tunnel.
    located towards the front, exactly where you would expect. the soft rubber outlet was prevented from seating by some (very wet) insulation. simply tidied up the insulation, refitted the rubber spout and all good.
    Best wishes
  • PPiper
    Thanks - I've not considered the aircon.
    Also FYI Autoglass don't fix seals.
    I'm also told the chasis drain can cause the issue and that it should be at bottom of the A pillar, where it meets the floor or in the front wheel arch but I can't see anything there. I may have to jack it up to get a better look.
    I'll have a good look at the weekend, inclding the air con.
    In the mean time dehumifiyer if working overtime.
  • Lynchyy
    2020 Discovery SDV6 First Edition Loire Blue
    Auto Glass dont fix seals, but if you smash your screen with a carbon tip (or it just happened going down the motorway), they replace the screen and the Seal.
  • PPiper
    Up date
    I know its been while but the weather has been very wet and there hasn't been many dry days to tackle it.
    I started by buying a huge sheet of plastic from screwfix and covered it with that as its parked outside. I left the dehumidifier running for weeks and it just felt damp at that point. I ripped off many panels outside and in and everything was dry other than the front carpets. I cleared the scuttle panel drains, there was some debris in there. It went for an MOT and passed, Thumbs Up but discussing it with the garage they said I should lift the foors and the under side is difficult to dry and it will start to smell. They were correct, not about the smell but they were still soaking. Also this pointed me to the air intake ducts. Under the pedals it was dry but wet on the centre console side.
    I took the scuttle panel off, the air intake is on the passenger side and it looks as if water was running under the scuttle panel, geting sucked into the air intake fan, then draining into the driver and passenger sides. I cleaned everything up, masking taped the window, put a bead of auto sealant in the lip where the scuttle panel sits, along the panel iself and then in the small gap the remains after. I'm still drying it out but fingers crossed that has sorted it. An easy way to diagnose this is to look at the pollen filter when its raining, accessible from behind the glovebox. You can see how it could happen when you do that. I'll let you know if its done the trick, I'm sure it will rain again soon.
  • PPiper
    PHOTOS
  • JBFUK
    Did it do the trick?
  • PPiper
    I think so, the problem is that it takes forever to get the carpets dry and so it' s difficult to know. At the minute I've taken the dehumidifier out and I just have some kitchen towel under the carpet. It doesn't get saturated but there is still some dampnest there. I think it is from the previous leak. I was going to reseal the windscreen with polyurathane but decided not to. The water shorted out the battery which I have replaced and the SOS system now has a fault, I am assuming that is aslo the LiFe battery and if I can find where that is I'll replace it but on the whole, all good. Thumbs Up
  • JBFUK
    Gosh I feel very fortunate that I spotted mine quite early. So far no electrical issues and I think I have the carpets dried out. I removed the kick plate on the passenger side and wedged something under the carpet - keeping an air gap open to help things dry out.
  • PPiper
    You do have to lift the carpets to get them dry, otherwse it would take forever. On th eplus side it doesn't smell damp. Out of interest what have you done to prevent water getting in on yours?
  • JBFUK
    I have run some silicone along the rubber gasket / glass joint on the inside while applying some outward pressure on the glass to open up the gap a bit. I dropped the front section of the headlining to make it easier to get at. I’ve also run some silicone into the channel between the windscreen and roof. I know that’s not the primary seal but I know part of it has perished and it does contribute to preventing too much water getting to the man seal.
