  • 747_JK
    Hmmmm, mine's not like that. That's not as a result of opening the boot when parked too close to something like a brick wall behind, is it? I know I made that mistake on my first D5, pressed the wrong button in my pocked and than cried....
    Wolfpack wrote:
    Lynchyy wrote:
    This work?
    Common fault but unusual on both sides ( I believe).
    Mine had it when I bought the car 6 years ago….not done anything to it, and it’s no worse now.
    Mine has the same tell-tale scuff mark but on one side only. It's usually on the left hand side of that plastic boot lid trim and caused by the way the locking mechanism works. It's a fairly common issue on the D5 and it appears on the slightly older cars (with slightly worn boot hinges) due to the boot lid electronically soft locking after closing. It's an audible event, you can hear the lock engaging and pulling the boot lid closed an extra inch or so against the rubber seal. It's not a thing to get too worried about as it doesn't interfere with the boot operation. It shouldn't get any worse over time. My Bling Barge is almost 9 years old and the boot still works fine Thumbs Up
  • Lynchyy
    Ahhh great. Was worried it would split the trim or get stuck. Cant wait to pick it up. 20 Plate D5 Landmark.
    Lynchyy wrote:
    Reassuring! Thanks very much. Yeah i think each one of the cars i've seen had both sides in this condition.
    Maybe they are ones adjusted too far the other way by a JLR technician. Rolling with laughter
  • Lynchyy
    Ha - No doubt. I work in an OEM so i know what goes on . . . . Anyway, seems harmless damage. I might try and sand them back a little and paint them in, or get the Tailgate adjusted in time...
    Again. thanks for all the help and support.
  • 747_JK
    Now you mention it, my first D5 had this. Until I was lightly rear-ended by a van, and the dealer bodyshop pointed it out, and said "oh we'll take care of this and respray as part of the repairs we're doing". I've not seen the marks on my current D5.
  • Dicky1961
    My 23 plate is the same, not getting any worse so I’m not worried, just gunna keep an eye on it.
  • Lynchyy
    My car is delayed. Was due tomorrow, but now next week i think. Need some parts for servicing from LR and also an issue with the Infotainment. Cant wait to pick it up...
