- squizzel
rattle in driver door cured
- Mole HD
Squizzel, you're a star.
As I mentioned in that other thread, I've got exactly the same issue with the driver's door having a tinny rattle like an old transit van when I shut it. The other doors are fine.
I thought it was the window regulator cables in my door vibrating like I mentioned at the time...but it looks like that door strengthener coming unbonded may well be the issue. Once the weather has improved a huge bit or after my trip to the stealership for the N877 security update next week, I'll strip my door down and do the same fix.
It'll also give me a chance to check the window regulator cables for any sign of rusting as I haven't had to replace the regulator on that door...yet.
I've got a new window regulator on the spares shelf in the garage for when I do need to replace it though. I bought it (just in case) when I replaced the OS rear one a couple of months ago.
Nice one mate
- ThatMartinChap
Wow, nice job !
I have the same issue and recently stripped my door to look for the rattle. That's one thing that I didn't check. Now I know how to strip the door it'll be a doddle to check this when I get a chance.
The other candidate is the B pillar trim, which feels like a clip has broken. That is also making a noise over bumps so I might have a go at stripping that out also.
D5 D300 R-Dynamic HSE MY21
