  • NiceNIck
    2022 Discovery SDV6 HSE Aintree Green
    Rear roof grab handle install
    Just bought a D5 HSE on a 23 plate and trying to improve a few bits on it.
    In the boot are the recesses for roof grab handles on both sides of the rear seats but no handles.
    Has anyone ever fitted any here? Dealer being a bit flakey on if there are brackets behind the linning. .
    I think the code is LR094971
    Do you mean these grab handles? I thought they were standard OE equipment on all D5's having the 3rd row seats...
    If they're not there on yours...I'd suspect someone has removed them for some reason.
  • NiceNIck
    I do, yes.
    Mines an hse r dynamic.
    Doesn’t have rear air con though. Can’t believe such cheap items are left off.
    I can cope with fitting them if the brackets are there.
    As per my pic, they haven’t been fitted as liner is intact.
    There's no brackets behind the actual handles...not separate ones anyway. The handles are secured by 2x T30 Torx bolts into some threaded holes direct into the bodywork behind the lining. I only know this because I was going to fit an after market boot rack in there and I had to remove the handles to fit some brackets where the rear grab handles screw into...
  • NiceNIck
    Ok, thanks.
    So are you suggesting, if a buy a pair of handles I can just fit them screw in? I can’t feel any holes or plugs behind the liner which is what’s making me nervous. If I could I’d have just order them.
    This is what I have for the other 4, assume screw behind the cover plates?
    Yup, the covers on the handles just pop off with a plastic pry tool or flat bladed screwdriver and the T30 screws are behind the covers. All that's visible behind my rear ones is a couple of holes in the liner where the screws go into the threads.
    Strange that yours doesn't have the rear grab handles as standard having the 7 seats though...it may be a later model adaptation. Since mine is a 2017 HSE, I'm just assuming that all D5's had them fitted. Maybe someone with a model of similar year to yours can offer an insight...
  • NiceNIck
    Maybe,, just annoys me!
    If I can’t feel any screw holes though do I need to self tap?
    I really don’t want to puncture the lining to find out the body work I’m supposed to be screwing into isn’t there!
    Pic now attached of the rest of them
    Not seeing any pics....
  • NiceNIck
    3rd time lucky…
    New to forum!
    That's better Mr. Green
    The 2 Torx screws are behind those little pop-off curved bits that are obvious... I'm only still assuming that the screw holes are behind the liner for your non existent rear grab handles though...so I wouldn't advise cutting any holes in your liner until someone with a newer model than mine gives the yay or nay on it. Thumbs Up
  • NiceNIck
    I’ll have another feel about up there…
    Until then….
    Does yours show you the tyre pressures in the spare.
    It did on the D4 but some ahole at LR seemed to think this was a bad idea!?
    My TPMS only warns me if the pressure is low on the spare...doesn't show the actual spare tyre pressure on the centre dash menu along with the other 4 tyres though. No idea why...
    I was the same being used to the D4 showing all 5 tyres...the D5 seemingly doesn't. Neutral
  • NiceNIck
    The Landrover experience eh!?
    Laughing
    Yup, you got that one right. Rolling Eyes
    After having a think about the rear grab handles and when I took mine off...or specifically the liner where they're fitted, it's not just soft fabric liner like the roof, it's a cardboard type liner with a narrow gap behind it and small 2 rectangular holes cut into it where a rectangular plastic block on the rear of the grab handles fits into. Even feeling the liner around the grab handles wouldn't work since there's a narrow space behind it where those block-bits on the actual grab handles fit into.
    The only way to demonstrate what I mean is if you remove one of the other grab handles to see exactly what I'm on about. It'll be obvious then why you can't feel the threaded holes where the handles screw into.
    It's quite possible that the threaded holes are there for the rear grab handles...but you wouldn't be able to tell unless you cut holes in that cardboard liner...which is all a bit drastic if it turns out the threaded holes aren't there. Neutral
