    Heavy steering
    Before I go and blast the dealer about another software glitch ….
    My steering feels variably heavy and a bit lumpy.
    It feels ok when making a turn but returning the wheel seems heavy …..both directions.
    There is a marked contrast in movement from finger tip to arm ache.
    I also think the steering wheel is not perfectly horizontal ….leaning towards 11 o’clock on perfectly flat straight road. It’s only a fraction out but I am dam certain I would have noticed it before.
    My question is…can steering lose positional calibration like other components ( eg like seats) Could it be getting the wrong signals from wheel turning?
    The car hasn’t been driven anywhere since it had the seat calibration done until today. I mentioned on another thread that the technician said there had been glitches with the N877 security update , including “a steering issue”.
    Before I go and read the riot act over this being yet another problem due to the update, I just wondered if there could be another reason ? To be clear it hasn’t hit any potholes, tyres are good, alignment was done 1month ago……I’ve driven it sense then locally with no obvious behavioural problems. But I’ve just don’t 200miles and it drives smoothly. But steering feels unpredictable. A couple of times I made a sharp pull out to overtake and needed more effort to bring it back straight, ending up over correcting….a bit unnerving till I started getting the new feel.
    Thoughts?
  • Towny23
    2017 Discovery Si4 HSE Corris Grey
    I had the same heavy steering fault. Turned out to be a rear wheel ABS sensor. Although I did have various warning lights illuminated on the dash - including ABS Fault message.
    No warnings showing.
    The car is perfectly drivable, just a bit “different”.
    In fact it’s reminiscent of when I towed with a D5 for the first time.
    It felt then like the steering had a slight delay in responding causing me to oversteer. With a large trailer on the back it felt unstable due to my jerky steering. But we’ve “got to know each others mannerisms” over the last 6 years. Lol
    Yesterday I went to overtake and it swung out further and faster than it normally does for my normal arm movement causing me to have to correct…then finding I had to use more force than expected to correct, than it did to move out.
    Call it coincidental but since the software mucking about, this feels like the cars decided to change how it steers …..which makes me wonder if the steering module needs calibration (if that’s at all possible)
    Think I will have to visit the dealer and face the inevitable argument. Life’s too short for all this!.
  • JBFUK
    Did you get anywhere with this? My steering feels a bit heavy and I’m not sure whether it’s actually a problem or that I’m driving the Defender day to day and the Discovery far less. It felt very heavy today.
    I did have the windscreen replaced on Monday and they recalibrated ADAS etc as part of that. A few days later I went to get something out of the car and got a battery low warning. This is something that’s happened before, after having an MOT somewhere other than the dealership. After that the battery went completely flat - the RAC chap said some third party diagnostic tools leave certain modules in a state where they don’t sleep. Anyhow, charged the battery overnight, cleared any errors (couple of random BCM errors about lights) and all seems fine.
    In terms of the steering, do you know whether it’s electric or hydraulic? If the latter I’m wondering whether it’s the drive belt slipping.
    Reading this thread, the first thing that sprung to mind was lane assist.
    Something mechanically wrong it could be,
    but the way you guys describe the symptoms, who knows!
    Speed sensitive steering! or lane assist,! now that would tie in with software / ads gremlins
  • JBFUK
    Could be. I might just disconnect the battery completely for a day to ensure every module has had a proper reboot.
    In my case, it could be that I've primarily been driving the Defender so perhaps my personal calibration as to what's 'normal' has been thrown off a bit. But today it did hit me that the steering felt heavy and it's the first time I've driven it since the windscreen was replaced. My wife drove it home from Autoglass and she's not that familiar with it so probably wouldn't have noticed.
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    Hi, the steering is electric on the D5.
    It’s also worth looking at the lower steering joint and checking the boot is intact.
    If the boot is split the water ingress can cause the joint to get stiff.
    I had mine off recently to replace the boot and it was stiff until cleaned up and re-greased.
    I thought I had an issue with the emergency lane assist but the issue hasn’t reoccurred since sorting the joint out even on the same roads.
  • nebc100
    I have a 2017 d5, and I don’t think the steering is electric on it… when the engine goes off (start/stop) the steering goes stiff unlike on my defender that DOES have electric PS.
  • BAZ8046
    It might just be the facelift version from 21 on, I wasn't aware the earlier cars had hydraulic steering.
  • nebc100
    I think that it was the TDv6 engined D5s (I don't know about the SI6, but I imagine they were the same) were hydrolic steering.
    The ingeniun engined D5s have the electronic Steering system.
    Maybe someone can confirm this?
  • BAZ8046
    Yes that makes sense that the SDV6's had the hydraulic system carried over from the D4.
    Mine is a facelift D300 so has the 6 cylinder Ingenium engine.
    Same applies to the lower steering joints, they can seize up on both.
  • mole
    Steering Issue
    Very interesting to read this. I have noticed that my steering felt “different “ for some time. Changed the tyres six months ago for the same type, but no improvement. Interesting that the security update could be the cause as thinking back that was about the same time as I started to notice the issue.Had the tracking checked, all OK.
    Difficult to explain what feels different, but I have to make small adjustments to the steering most of the time whereas before it kept perfectly straight.
    I have never been a fan of electric steering!
    Hoping someone can discover the cure!!
    Goodness me, another rodent appears. Laughing
    As for the Bling Barge after the recent N877 security software update at the dealership in Inverness, I haven't noticed any weirdness...steering or otherwise. I replaced the knackered and growling OS front wheel bearing that cropped up during the 250 mile road trip to said dealership a few weeks ago, that eliminated the very slight vibration I was feeling through the steering wheel...
    Other than that, for heavy or inaccurate steering, I'd suspect water ingress into the steering linkage through a torn gaiter as Baz mentioned...
  • JBFUK
    I had a warning on last years service that a steering linkage boot had split so they advised replacement. As the service adviser described it, sounded like it was an internal joint in the steering column so I didn't have it done and I haven't been in too much of a hurry to deal with it. They suggested the joint/linkage needed to be replaced at a cost of around £400+ labour as they don't sell a replacement boot.
    If in fact the split boot they were taking about is external and it's led to the join seizing up a bit that would explain why I feel like the steering is heavier than it used to be. How do you access this to inspect? Is it an under-shield off jobbie?
  • BAZ8046
    It can be seen down the side of the engine on the drivers side.
    The boot is around £40 or less and the joint needs to be removed from the car.
    This is just a bolt top and bottom but the boot is awkward to fit.
    It is recommended to replace the bolts and the torque is 30Nm.
    You really need a small cone of some description to get the boot over the joint.
    Hope this helps.
