    Timing belt
    Hi All,
    The car is 8 years old, done 65,000 miles.
    I guess I need to replace the timing belt.
    Couple of questions:
    It's the tdv6, does it only have one belt?
    On previous cars I've always bought timing belt and water pump kits, is it a different setup on the disco 5, I can only see kits with one belt, 3 pulleys, no replacement bolts or water pump, which I had expected?
    What brand belt is best?
    What else should be changed at the same time?
    Phil
  • nebc100
    It actually has two belts that need replacing.
    One timing belt, and then one belt at the back for the HP fuel pump.
    Note: on the 3L tdv6, the rear HPFP is also “timed”. It won’t kill the engine if not timed properly, but it won’t run as well as it should.
    For make… I think mine was dayco.
    Thanks for that Neb.
    Should I be replacing the pump as well on the small belt, or anything else?
    Phil
    After saying that, it sounds pretty dumb to suggest replacing a HP fuel pump, don't know what came over me Smile
  • nebc100
    No… pump isn’t replaced… just the belt.
    Thanks.
    Any other thoughts on jobs to be done at the same time?
    Eg. How is the water pump driven?
  • nebc100
    When I had mine done I was recommended to replace the water pump as it is know to leak after a certain time and since you are taking most of this off anyway………
    I replaced the water pump and the 2 main camshaft pulleys, the camshaft pulleys aren't really necessary but a pair only cost an extra £125 over the rest of the parts.
    That's 3 belts (FP belt, main timing belt and auxiliary belt), a water pump and 2 camshaft pulleys. Besides the idlers and tensioner pulleys, that's about it for a timing belt replacement...
    Thanks Mole.
    Planning to get on it on Saturday.
    Weather permitting.
    Good luck Phil...I'll be replacing my OS front wheel bearing hub...and the back brake disks which I still haven't done thanks to the weather. Rolling Eyes
    Once again...weather permitting. Laughing
