- Chillyphil
Timing belt
Hi All,
The car is 8 years old, done 65,000 miles.
I guess I need to replace the timing belt.
Couple of questions:
It's the tdv6, does it only have one belt?
On previous cars I've always bought timing belt and water pump kits, is it a different setup on the disco 5, I can only see kits with one belt, 3 pulleys, no replacement bolts or water pump, which I had expected?
What brand belt is best?
What else should be changed at the same time?
Phil
- nebc100
It actually has two belts that need replacing.
One timing belt, and then one belt at the back for the HP fuel pump.
Note: on the 3L tdv6, the rear HPFP is also “timed”. It won’t kill the engine if not timed properly, but it won’t run as well as it should.
For make… I think mine was dayco.
- Chillyphil
Thanks for that Neb.
Should I be replacing the pump as well on the small belt, or anything else?
Phil
- Chillyphil
After saying that, it sounds pretty dumb to suggest replacing a HP fuel pump, don't know what came over me
- nebc100
No… pump isn’t replaced… just the belt.
- Chillyphil
Thanks.
Any other thoughts on jobs to be done at the same time?
Eg. How is the water pump driven?
- nebc100
When I had mine done I was recommended to replace the water pump as it is know to leak after a certain time and since you are taking most of this off anyway………
- Chillyphil
- Mole HD
I replaced the water pump and the 2 main camshaft pulleys, the camshaft pulleys aren't really necessary but a pair only cost an extra £125 over the rest of the parts.
That's 3 belts (FP belt, main timing belt and auxiliary belt), a water pump and 2 camshaft pulleys. Besides the idlers and tensioner pulleys, that's about it for a timing belt replacement...
- Chillyphil
Thanks Mole.
Planning to get on it on Saturday.
Weather permitting.
- Mole HD
Good luck Phil...I'll be replacing my OS front wheel bearing hub...and the back brake disks which I still haven't done thanks to the weather.
Once again...weather permitting.
- JBFUK
Has it been serviced following the recommended schedule? If so it will have had belts at 84m or 110k.
- Chillyphil
No the belts weren't changed, that's why I'm doing them now.
- Chillyphil
It's 2018 with 60000 on the clock.
So the previous owner decided to save some money and take a risk last year by not doing the belts.
