  • Dtac122
    2019 Discovery TDV6 HSE Santorini Black
    Misfire sdv6 or just restricted performance
    Hi guys
    I am desperately looking for some help or guidance, the other day foolishly or not cleaned the throttle body out with some carb cleaner since then the engine has been suffering with a misfire or similar. It appears to be only from the bank on the drivers side.
    Obd fault codes are:-
    P00bf
    P2621
    P0102
    P010c
    P0107
    I have replaced the throttle body and coded that into the car
    Smoke tested the manifolds throttle body etc for air leaks again all fine.
    Replaced the MAF sensor on the drivers side bank
    It’s been recovered to a local Garage whim has removed all the diesel injectors and has them professionally tested- all came back fully functional no faults found?
    Garage believes stuck open valve perhaps?
    Requiring the rocker cover to be removed and then replaced/renewed both sides of course.
    Anyone had anything similar?
    The car starts but won’t rev up. Throttle in the throttle body moves in reaction to the pedal but that’s it. Distinct smell of unburnt fuel from the exhaust.
    Any info guidance gratefullly accepted.
    Hi Dtac.
    I don't think you cleaning the throttle body had much to do with this, if the butterfly valve isn't sticking and the boost sensor isn't chucking out turbo overboost warnings on the dash, you should be fine... From the symptoms you describe, it still sounds suspiciously like a MAF sensor rather than anything mechanically complicated like air leaks, injectors or stuck valves, I looked up the fault codes on your list and it offered this...
    Quote:
    The P00BF fault code in a Discovery 5 SDV6 indicates a problem with the Mass or Volume Air Flow "B" sensor circuit, which may affect engine performance. Common causes include faulty sensors, air leaks, or issues with the powertrain control module (PCM).
    The P0102 fault code indicates that the mass air flow (MAF) sensor is sending a low voltage signal to the engine control unit (ECU), which can lead to performance issues like rough idling and poor acceleration. Common causes include a dirty sensor, electrical issues, or air leaks in the intake
    P010c fault code also points to the B circuit MAF sensor....as I suspect do all the others. So, looks like either the B circuit MAF sensor or a PCM fault...just going by the fault codes...
    My 2017 3.0L TD6 only has one MAF sensor (single airbox and turbo), I'm not sure if your twin turbo 3.0L SDV6 has 2 MAF (A and B) sensors like the SDV6 D4 had. It has twin air boxes so it should have 2 MAF sensors. I've never been under the bonnet of an SDV6 D5 so excuse my ignorance.
    Might also be worthwhile checking the boost sensor at the back of the throttle body. There's no error code or turbo overboost warning on the dash to indicate it's an issue, but there again, since you've replaced the throttle body...I'd still check the connector if nothing else.
    Let us know how you get on when you find the cause of the problem. It's always helpful should someone else come across the same issue. Thumbs Up
    Hi Mole,
    I had cause to replace the throttle body on my tdv6.
    I installed a third party throttle body and started getting all sorts of faults showing up.
    Turned out to be simply poorly fitting air intake and egr pipe.
    It was also a pita to fit.
    Eventually fitted an original lr throttle body, simplest installation, everything fitted and all the fault messages disappeared.
    Don't know if that's relevant to this problem?
  • Dtac122
    Thanks both the throttle body was in fact a 3rd party part. It came with a new MAP sensor but I have also attempted to fit the old one back as prior to the current fault it came up with no OBD codes.
  • Dtac122
    The volume air sensor I believe is the sensor fitted to the Venturi which is clipped to the throttle body? I have swapped with my l405 with a similar engine and no current faults, made no difference at all. Sadly.
    Chillyphil wrote:
    Hi Mole,
    Could well be if there's air getting in through a poor fitting seal...I'll remember to buy OEM if I ever have to replace mine.
    Thanks Phil. Thumbs Up
  • Dtac122
    No not an air leak as we have had it smoke tested from the throttle body onward.
  • Beno2
    Hard reset
    That's the boost sensor on the throttle body...which isn't faulty according to your error codes. You'd also have a turbo overboost warning on the dash. The Mass Air Flow Sensors (MAF's A & B) are attached to the air filter box by 2 bolts and the big air hoses from the air box are clipped onto them.
    Looks like this...
    Like I said, you should have 2 MAF's on your SDV6, one for the air hose coming from each airbox. As to which one is the B sensor... which seems to be the root of your problems according to the fault codes...try replacing one of them...if the error codes and fault persist, swap it over to the other side, they're both the same part.
    A replacement MAF sensor costs around £70, depending on brand and where you buy it. they're fairly standard so brand make...OE or not...doesn't matter. I'd usually go for a mid price range trusted brand like Pierburg or Delphi...but that's just me. You can also buy the sensor unit separate from the housing...it just clips into the original MAF sensor housing.
    You can find a variety of MAF sensor options here.
