  • Bradley01230
    Land Rover Discovery 5 Help Needed
    Hello all,
    I recently bought a Land Rover discovery 5 and it has been absolutely brilliant in fact we all love it however last week we got restricted performance.
    Since then we have had it come and go. After a couple days engine management line came on.
    Since then my friend has smoke tested from after air box for leaks in air inline and when plugging into snap on OBD we are getting the faults as shown. Here is the interesting part which I was hoping someone else may have had experience of this and can advise. When I put my foot down I am getting what sounds like a whooshing from the air vents (more so drivers side) which sounds like it’s controlled by the accelerator, as I push the accelerator it gets louder when I let off it quiets down. This does not happen in idle therefore thinking it’s a boost thing off the turbo. I have no black smoke so think turbo is all ok and intact. Wondering if a boost pipe or a waste gate issue could be the cause of my problems and if anyone has had similar? Only thing I find confusing is why it’s kicking up MAF sensor faults when it’s after that it’s happening if turbo boost pipe etc
    If anyone can help that would be fantastic and much appreciated. I don’t mind looking at things or checking just trying to get an idea of where to start.
    Thanks in advance.
    Brad
  • Beno2
    Check your turbo hoses for any splits. They might look OK but if you squish them all over you may discover a split
  • Keijo
    2017 Discovery TDV6 SE Santorini Black
    Does sound like a boost leak. Classic symptoms.
    look for any oily residue around engine bay around the inlet pipework. My leak was invisible until I squeezed the pipe, it gave itself away by the oil mist residue around the area.
  • Bradley01230
    Thanks for the support. Do you know the easiest way to check turbo hoses. I believe the turbos are situated at rear of engine.
    Is it come from underneath taking off under floor or is it from the top engine bay?
    It’s the 3L v6 which is believe I forgot to mention in my post. Apologies.
    I have old eyes, I struggled to read those error codes in the pic you posted which doesn't help...
    Besides the engine management light and the MAF DTC's on the diagnostics, are there any dash warnings like 'Turbo overboost' etc?
  • Bradley01230
    Yeah sorry didn’t think about how difficult it is to read the image. I have typed them in below if it helps.
    Apart from engine management light and restricted performance we have had no other visual or worded warnings just the whoosh I talk of that is coming from the vents when pushing down accelerator,
    Thanks for offering support,
    P2279-64 - Intake Air System Leak Signal Plausibility Failure
    P006A-85 - Manifold Absolute Pressure - Mass Or Volume Air Flow Correlation
    - Signal Above Allowable Range
    P0113-17 - Intake Air Temperature Sensor 1 - Circuit High Input - Circuit
    Voltage Above Threshold
    P007D-17 - Charge Air Cooler Temperature Sensor - Circuit High - Bank 1
    Circuit Voltage Above Threshold
  • Beno2
    Codes do help most of the time. But a code is recorded by a sensor which in-turn has possible other items that could cause the fault. Let's say your issue is your turbo hose, this hose cannot give you a fault code. It will only be discovered checking manually. My split hose was 2 inches long and invisible until I squeezed it.
  • Bradley01230
    Hi thanks for feedback
    Out of interest what was the location of
    Your hose which had split. I’m struggling to work out where the turbos are and hoses which could be playing a part to check. Watched a few videos on YouTube but no real location or how to get to them as yet so trying to work it out. What I don’t want to do is start taking parts off the car to find I’m not in the right area. 😂🤦🏻‍♂️
    This is needle in a haystack stuff
    Isn’t it 😩
