- ChrisJerman
Sudden loss of Power and running rough
My son was driving our 2017 TDv6 when all of a sudden it lost power and started running rough. No lights have come on dash but it doesn't have enough power to move itself, it did however have enough power to tick over for 30 mins while we towed it home and still starts and ticks over with no smoke or blowing through the oil filler cap.
I obviosly fear a snap crank but would of thought it would of seized if that had happened or at the least sysmptons would progressively get worse where as it has got no better or worse over 30 mins of tick over.
Any ideas as to what it might be before |I get it booked in ?
- ChrisJerman
Fpund the issue now it's daylight. The timing pulley has split on the right hand bank. Not great but hopefully a lot more fixable than a crank !
- Mole HD
Good luck with the repair. It's not common having a pulley split or break but it can happen after a belt change and it's not nice. I replaced both pulleys when I did my timing belts last year...just in case.
- ChrisJerman
Had the timing belt replaced about 18mths ago but not the pulleys. Pity I didn't change them but to be honest I'm just relieved it's not the crank
