- Westy
Jack location
Hello,
Thanks for letting me into the forum. I’ve just moved from an F-Pace to a 2020 MY Discovery 5 and really enjoying it.
I’m hoping you can help with a query, as I don’t have any other D5’s to compare against. When I purchased the car, I noticed that Jack boot cover wasn’t shutting properly and after reseating the jack, I can now get it to close but I’m worried about the fact the base of the jack sits on the earth strap that’s in that compartment. It seems strange as I would have thought over time that the jack would rub on the wiring.
Can I please ask other D5 owners if this is standard and the jack should be resting on the earth strap or has my car being altered?
Thanks!
- Mole HD
- Westy
Thanks Mole HD, that’s exactly what I was looking for! The boot insert looks great 👍
I have the jack in the bag, but at the moment it’s sitting directly on the earth wires in that cavity when strapped in, as I don’t have the foam underneath. Is it just a soft foam block it should be sat on? If so, I’ll try hunt it down under the boot floor!
- Mole HD
Aye, it's just a loose rectangular bit of foam block padding...if you have an old sofa cushion or anything like that lying about, just hack a bit off and squash it in there.
The foam block sometimes gets shoved back toward the light fittings or further forward toward the battery compartment, it may well be in there somewhere.
