- BAZ8046
D300 engine cover rubbing.
There should be a rubber bush in the hole on the engine cover and all 4 of them should push down on to upward pointing plastic balls that retain the cover in place.
It shouldn't be making any contact with anything metal.
Are you sure it's the correct cover for your engine?
- BAZ8046
