- discus
Pivi Pro 4.5.0
Has anybody had this successfully install?
It has downloaded several times and I have scheduled it to install that night, but in the morning there is no mention of it and it is still on the old version. Then a couple of days later, it again prompts to install the same update.
Think I have done three times now, if not four. No idea why it is not working, all previous updates have installed OK.
2019 Discovery HSE SDV6
- DG
23 year LR veteran > D2 GS 2003 > D3 S 2006 > D3 HSE 2009 > D4 HSE 2013 > D4 HSE 2015 > D5 HSE 2018 > DS HSE R-Dynamic P300e 2021 > D5 HSE Dynamic D350 2025
- discus
It finally successfully completed this update last night. Must have been the fourth or fifth time I accepted it. Curious if it is just a glitch, or if the updater was downloading extra required items every time. Who knows how the process works, but glad it finally did.
- 747_JK
I found the key with the updates - to make them work first time - is when they are offered, don't hit the button which says do it now, but schedule it for later on. Even 30 mins later. Every time I've scheduled the updates, they've worked. Whenever I said do it now, I've had a less than 50% success rate.
- discus
They're flying in now, 4.5.1 arrived today, and installed first time.
Quote:
Discovery
This update improves the Wireless Charging Pad performance.
Note:
As part of this update, please ensure the Wireless Charging Pad and surrounding area are completely clear of all items - especially any metal objects - before starting.
In addition, this update delivers:
Refined powertrain behaviour for 6-cylinder diesel vehicles in high crosswinds.
Improvements to deployable sidestep operation: obstructions now pause the step at the obstruction point rather than triggering a full retraction.
Changes to improve wireless charging to support more devices.
This update brings bug fixes and general performance improvements to the following systems where applicable:
Powertrain.
Note: Improvements may differ based on build year, specification, or factory fitted optional extras.
