- Andy p
- BAZ8046
Yes the windscreens are still an issue and I had to have mine re-fitted on a MY22 car.
When it was removed it was completely de-bonded from the body along the top.
The easiest way to tell is to apply some light pressure to the top of the screen from the inside and look for movement on the outside.
If the screen is moving it is not bonded to the body, it should be rock solid.
I had mine re-fitted by a local firm as life is too short to deal with LR.
- Andy p
