  • Lynchyy
    2020 Discovery SDV6 First Edition Loire Blue
    Engine Bay Smoke
    My engine bay has recently started smoking. Took a video of it today.
    Now, couple of things to note.
    1. I know nothing about cars.
    2. Ive sprayed ALOT of WD40 into the hood hinges (which did douse the Engine Cover)
    3. It seems to have also pooled at the bottom end.
    Hopefully this link works.
    Any help much appreciated
    https://youtube.com/shorts/n8W3f-kwAKM?si=NtbzoO4bAX3pgwkI
  • Lynchyy
    Photos
    From what I saw on the video, it doesn't look like surface WD40 causing the smoke, it looks more like there's something spraying or leaking onto the engine when you rev it. From checking the pooling on the bottom end, is it diesel or oil? I can't tell from the photos.
  • Lynchyy
    I will attempt to remove this sleeve tonight. I’m thinking it could be diesel.
  • Lynchyy
    I had thought it was me over spraying WD40, but reading online, Diesel and WD40 have similar smells when burning. So i'm now thinking this is a diesel leak.
  • Lynchyy
    This Bracket looks like it’s peened, so will be a tough one to get off and a 1 time fit I guess.
  • Lynchyy
    This is the wet area. Anybody know if this is fuel or oil in and around here.
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    The pipe on top is the EGR pipe that feeds in to the intake housing.
    If it's diesel the most likely source would be a leak off pipe on the injectors.
    Try and have a look at the injectors and see if one is obviously wet.
  • Lynchyy
    Sorry for not knowing a thing about cars.
    Is this an injector? As this casing seems wet.
  • BAZ8046
    No, the injectors are under the foam cover in the middle of the rocker cover / inlet manifold.
    You can't remove the foam easily but can lift it to see what is going on.
    Is it definitely diesel?
  • Lynchyy
    Yeah defo diesel.
  • BAZ8046
    See if you can see the leak off lines from the injectors as this will be the most likely source.
    They will be under the foam cover which is blue on the attached screen shot.
    The second screen shot then shows the leak off pipes themselves.
    It might take a bit of dismantling as I can't remember what is in the way.
  • Lynchyy
    Thanks for the help Baz. Amazing that. Stripped down. Pin hole in fuel injection pipe.
  • BAZ8046
    No problem, glad you found the leak, they are not always easy to track down.
    Nice job in tracking it down Lynchyy...and for posting the results up. Folk tend to forget that it all helps if someone else has a similar issue. Thumbs Up
    Baz, awesome detective work from a couple of screenshots. Bow down
