- alex08
Anyone using an amateur band radio in the D5?
Anyone installed an amateur band radio in the d5? I've an Icom unit I want to put in. Obviously the power is no issue with the battery in the back, but how do you get the antenna cable out? Years ago I used a glass mount for 2m but I want to run a 10m antennal on the roofrack. Short of drilling a hole in the body I can't see an easy way to get it thorugh from the inside as it is chunky coax. Any ideas/solutions would be very welcome.
Alex
