  • Markj
    2020 Discovery SDV6 HSE Lux Farallon Black
    B14A9-13/B14AA-13
    Hi all,
    Having plugged in my recently purchased Gap IID to check for fault codes, I found there to be the two in the subject box.....having Googled these codes they point towards the TCU, and possible battery failure amongst a few other possibilities.
    Can anybody point me in the direction of it's location please, as I seem to be getting conflicting information when searching the internet.
    It's a 2020 D5 HSE luxury
    TIA,
    Mark.
  • harrythespider
    located behind c pillar on nearside, involves removing plastic trim etc to reveal. shop around for replacement battery, price varies considerably.
    Like Harry said, as your Disco is a pre-facelift model, the battery compartment is in the boot on the right hand side just behind the 2nd row seats (next to where the jack is). I always buy my batteries online from Tayna batteries. Link
    Quick how-to vid on replacing your battery...poor quality video but it's all there was. Remember to reset the BMS (Battery Monitoring System) with your IID tool once you replace the battery.
  • Markj
    Thanks both,
    For clarity, it's the TCU location I'm asking about as the fault codes (B14A9-13/B14AA-13) that appear on the IID, suggest that the battery in it might need changing.
    I seem to remember seeing something online that shows it's behind the N/S C pillar as Harry suggests, but I would like it confirming before i start pulling it apart and probably breaking plastic fasteners in the process.
    Ah, clearer now what you're after, Mark. The TCU (Telematics Control Module) If that's what you mean, is behind the OS upper c pillar plastic trim. You have to remove the plastic trim panel to gain access.
    The battery compartment you can make out from the image. Once the battery pack has been replaced, the TCM has to be recalibrated either by an IID tool or by dealership software.
    It's not a thing I've messed with since I use my phone rather than the on board connectivity software. My TCM doesn't have any errors...but being an early 2017 model, it's 3G only...which makes it utterly useless.
  • harrythespider
    Mole, are you sure of the location? theTCU battery I replaced was definately on the nearside/passenger side rear behind the c pillar.
    You're more than likely right Harry. I've never had cause to look for mine...and the workshop manual isn't too clear which side it's on. Since you've already done the job, I'll bow to your knowledge. Thanks for picking that up. Thumbs Up
  • Markj
    Harry,
    Did you recalibrate with the IID when you changed the TCU battery pack, can you remember why you changed it and did it solve your issue?
    TIA
