  • Huggs153
    2017 Discovery TDV6 HSE Lux Firenze Red
    TailGate restraining straps
    Hi Collective
    Does anyone have the part number/ supplier for the Tail Gate retaining strap thing? The plastic outer sheath has failed and causing a lag when the tail gate seat thing opens......
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    Not sure about the part number but you can just strip the rest of the coating off and they should work fine again.
    If you detach the end from the car you can pull the full length out and use a sharp blade to remove the remaining coating.
    I did this with mine and it has been fine ever since.
  • Huggs153
    Cheers Baz
    Thatcher a good shout. Another little Sunday morning job on my radar.
  • Huggs153
    Found the park number.
    I have taken the mechanism out and photographed the PN…
