- Russell
Oil change and pump to remove oil
For those that do their own changes.
What pump do you use to remove the oil ??
- Russell
Does it work OK as I have heard that the had pumps start to play up after one or two uses.
I've only used it about thee times but it hasn't broken yet.
- Russell
- Mole HD
I use the same manual vacuum pump and I've also got a vacuum bottle I connect to the compressor in the workshop. Both are just as quick.
