- Chillyphil
There are many others to chose from.
Also, eBay in Spain if you have a personal address or relatives there.
- Grunders
I bought one from Amazon… delivered last Friday… took 20 minutes to fit, all sorted
- Chillyphil
Well done, thanks for the update.
- spoon63
Faulty window regulator
Does the L462 Discovery suffer a design flaw given that the window regulators fail as the cable corrodes?
This fault appears more predominant in the disco compared with other landrover models.
A year ago, I had the drivers window regulator replaced under warranty.
This year, both the rear window regulators failed.
Whereas in the past failing window regulators were covered by the LR extended warranty, this no longer appears to be the case. The justification being corrosion.
No car window are watertight and are designed to allow water to run down the inside of the door and out the bottom, so what is going on with the discovery that the cables corrode? The only saving grace is that it only takes ~30 mins to replace the window mechanism, as shown in the video in this post.
- Mole HD
The cables on the window regulators aren't greased in the factory during assembly...hence why they eventually rust and snap frequently.
After market regulators come with pre-greased cables...OE ones don't...or certainly, the NS front OE one I fitted wasn't. The OS rear I bought from eBay was...go figure.
- yellodisco
Window Regulator
is it worthwhile doing preventative maintenance, i.e. taking off door card and greasing the cables. It seems quite quick and easy to remove door card, so might give it a shot and hopefully reduce risk of failure
- Mole HD
Trouble with that is you can't really get to the bits of cable that usually rust...I did attempt that kind of preventative maintenance early on but even taking the regulator off so I could spray the cables with silicone grease didn't help much.
I've replaced 2 on mine that the cables had rusted through and broken, one front, one rear. The replacement regulators from eBay were relatively inexpensive (compared to OE Land Rover parts) that I just bought spare regulators to stick on my parts shelf for when the other 2 eventually do break.
The 3 replacement regulators from eBay cost less than one OE Land Rover one...and they all come with pre-greased cables.
