  • ChaddersP
    2019 Discovery SDV6 HSE Yulong White
    Restricted performance warning 🤬
    I’ve had the restricted performance warning message come on with the red exclamation mark in the red triangle! Then can’t go above 50mph. It goes off and resets when you turn the engine off and resumes normal performance. It will come back on around 3500/4000 rpm under acceleration.
    In short chat GPT points to turbo issues which makes sense when accelerating. I’ve booked it in for diagnostics. However what’s your experience and best guess?
    Hopefully it’s not typical poor landrover reliability 😤thanks
  • BAZ8046
    2022 Discovery Td6 S Carpathian Grey
    Hi, on the SDV6 it is normally either an air leak or a sticking actuator on the secondary turbo or cross over valve.
    A read of the codes should point you in the right direction.
    Here is a screen shot of the codes from my old car last week which has the same symptoms and does have a sticking actuator.
    Hope this helps.
  • ChaddersP
    Thumbs Up would anything relevant have been disturbed when the belts were done? Only happened since then
    Unfortunately can’t see the image even when zooming in
    It’s a knocking bet there’s a pipe off or not properly refitted after the belts were done.
    Ask me how I know. Embarassed
  • ChaddersP
    How do you know? 😊
  • BAZ8046
    Yes I would say there is a good chance it is just an air leak from a pipe not refitted.
    There are quite a few that have to come off as they are attached to the cambelt cover.
    Fingers crossed it is an easy fix.
    My guess would be the rubber O ring where the boost pipe fits onto the front of the throttle body...or the spring clip holding the boost pipe on hasn't been fitted correctly.
  • ChaddersP
    Thanks guys are the hoses seals etc easy to check yourself? What needs to be done for access? A friend had an OBD scanner these are the relevant codes
    P004B-84 Turbo boost control B signal below allowable range Secondary turbo charge-air shut-off valve or its control system
    P0234-77 Turbocharger overboost condition Boost pressure/control is exceeding its permitted operating limit
    P259B-71 Turbo boost control position sensor B – actuator stuck Turbine intake shut-off valve is not moving as commanded
    Turbo overboost is usually caused by a sticking butterfly valve in the throttle body, might be worthwhile checking that it opens and closes freely.
