    Is it the earth stud
    Long story short - ish.
    2018 2ltr HSE Lux. Battery went totally flat in April 23. AA fitted new battery, it went dead within 24hrs. Recharged and took car to Indi, they reported no adverse drain on the battery. Been OK since with the standard ‘low battery’ warning on occasion which went away for a while after a good charge.
    Eventually message started to get more regular so as battery had five year warranty just got the AA to replace it two weeks ago, he said he reset the BMS. Been OK since with stop start eventually working but as soon as the engine stopped it restarted without drawing breath!
    Went out today and forgot to turn the stop start off on one leg of the journey, car stopped at a junction, went dead, then dashboard lit up with all sorts of warnings. Car still in Drive but no running engine. Went back to Park then Drive, engine started, we continued our journey with warnings suppressed.
    Got to the pub, parked, came out, car started no problem.
    Got home, pulled into drive, stopped the engine, car went dead. Nothing, can’t lock or anything. Can’t open the boot to get to the battery. Opened bonnet, voltage on the jump start studs about 3v. Connected charger, digital screen flickering from 5 to 6 volts (approx).
    Connected wife’s car with jump leads, lots of sparks but car comes back to life as if nothing had happened! 🤬
    Edit - forgot to add, I have a Bluetooth battery monitor fitted on the battery, it could not connect when the car was dead, the monitor is connected to the positive terminal and the lower battery clamp so does not bypasses the earth stud.
    Two positives - we had made it home and JLR phoned to ask if the car is OK.
    Question(s): is this the dreaded earth stud problem or, what else should I check?
    It certainly has all the hallmarks of being the earth stud as the culprit, move the earth strap onto one of the alternatives in the meantime and it should sort those issues out.
    Thanks Mole.
    Is this stud, as posted by Cordon, an acceptable place to move it to:
    https://disco5.co.uk/forum/thread2651.html...p;start=30
    That'll do fine. There's a couple of alternative earthing points close to the battery.
    Original earth point.
    Alternative.
    Brill, thank you. Guess what I am doing tomorrow ……
    On the D3 and D4 your symptoms we’re synonymous with a failed/failing alternator but I’m unsure if this applies to the D5.
    A failing alternator has all the hallmarks of a tired battery, so you obviously replace it and normal service returns until the following day when your new battery is also paggered. If you get her running again, check the alternator output across the battery with a multimeter. A good reading is well over 12v, preferably over 13v and nearer 14+v at initial start up.
    Thanks Narpy.
    The AA man did do a check and said the alternator was charging fine, the old battery was not taking the charge.
    I will move the negative lead and do those checks. I am also going to check the voltage across the battery and the other end of the negative lead before I do any work to see if there are any tell tale signs. I also hope that visual inspection of the connection will tell me something. I fear that not identifying any issues will leave a distrust in the car which will be hard/long to overcome and I am due to travel down to Tavistock next week, a 3 ½ hour journey…… 🤞
    Update
    Here is an update of my efforts:
    In the cold light of day, the answer was in the original (updated) post. Due to getting the dreaded Low Battery warnings all the time, I had invested in a Bluetooth battery monitor and wired it to the positive terminal of the battery and then, for ease, the chassis. When the car went dead, so did the battery monitor so the ONLY place the fault could be was the connection between the battery -ve terminal and the chassis. Excuse my poor drawings but hope this picture helps to explain that:
    Before I started I checked the voltage at the battery terminals and between the battery +ve and the chassis with a Fluke. There was only 0.03 v difference.
    I used a jump lead from the battery -ve terminal to the chassis to hopefully keep the car alive. It was hard to get the clip even near the terminal but it worked:
    The -ve lead connection to the chassis has a lug on it so you can’t connect it to a flat surface, I had to cut that off:
    I then had to drill the terminal end to 8mm to get the chosen bolt through it. I then filed off both sides to make sure the connection was good.
    I chose to connect the lead to the bottom battery clamp, it’s made of metal and has three bolts going through it to the chassis so, in my opinion, stands a much better chance of a good connection:
    I started the car and left it at tickover, the voltage across the battery and battery +ve to chassis was 14.4v. After a couple of minutes at tickover it had risen to 14.85.
    I now just need to take the car out with the stop start on and see what happens - that’s a job for another day!
