  • winger
    Seat Belt Chime
    The plug in/release sequence trick still works a treat.
    Ignition on, door closed, plug and release eight times and the ninth plug in you will get a single chime confirming the warning chime is switched off.
  • sportcoupe
    Do you not wear seat belts across the pond?
    Ordered - HSE 3.0 V6 Diesel Kaikoura Stone 20" Black pack + more.
    2016 Jeep Wrangler Unlimited Rubicon
  • winger
    Of course. 'Tis the law. However, there are plenty of occasions when I drive off the road, and having a belt on is a pain, and the ding is even more of pain!
  • Chrismcnaz
    Thats a good tip as i used to just put the belt clip in accross the seat and drive sitting on it in my D3 when off road to stop the bonging.
  • achichon
    Gibraltar
    will defo try this! thanks.
    does this stay OFF until you re-enable it? (how do you re-enable it?) or does it go back to normal after the car has been switched off ?
  • Down & Dirty
    achichon, it will stay off until you do the sequence thingy to re enable Thumbs Up
  • achichon
    Gibraltar
    so same sequence again re-enables it correct? thanks!
  • Down & Dirty
    Correct Thumbs Up
