- G4UJS
Front console Cooler/fridge
Just wondering does the cooler/fridge only work when the ignition is on or can it still operate when the D5 is parked up
Rob
- Platypus47
Hand Book should give answer, but most things that actively consume power go off either with ignition or a predetermined time after (eg radio).
- Pcheaven
Mine only works when the car is on. The power switch is illuminated when there is power.
Not a great cooler. More a keep stuff that's already cold cool.
- eelpout
based on previous LR3/LR4's I've had, it's off when the ignition is off.
This one in the D5 though is much improved though, it's now deep enough to hold a Gatorade sized drink, The last one I swear was designed for Apple juice boxes.
- Road Runner 2017
Mine also only powered up when the car was on, and powered down when the ignition was switched off. It had a lime green light on the on/off switch. Kept the soft drinks cans nice and chilled the only time we used it. (The D4 cooler worked the same as the D5 one did).
