  • AndrewS
    Route Planner Android
    The app works OK ish. It won't find places or post codes. It does however give you the ability to click on the map and use the drop pin as your destination.
    I need to make sure I have downloaded the correct map including the place name/post code search ability.
  • pdes
    Mine worked perfectly well on my Xperia Compact but I have just upgraded to a Galaxy S8 and the search function finds nothing! I have reinstalled and rebooted a number of times but to no avail. Trouble is there is no one to go to for support.
    Series 1, 1953, 86"
  • AndrewS
    The route planner app now has a search facility that works. Nothing has changed on my phone as far as I am aware. One minute the app would not even find London now it seems to have a comprehensive search facility.
  • pdes
    Yep, mine suddenly started to work as well. Some sculduggery methinks!
    Series 1, 1953, 86"
