  • AndrewS
    Going proper off road tomorrow
    All loaded up ready with front and rear recovery points exposed if needed.
    Where you going
  • AndrewS
    Not far from Peterborough Wink private day to see what the D5 can do 😉
  • J77
    You sure? It might break in half Laughing
  • AndrewS
    If it does it does Thumbs Up
  • Landieman
    Is there a nack to removing the rear cover or is it meant to feel like you 'might just' remove the whole bumper too? (I've had mine off a few times and it doesn't feel as easy to get on and off as the front one)
  • AndrewS
    Its a case of pull and hope for the best.
  • AndrewS
  • Grianaig
    Very impressive. Thumbs Up
    MY 2014 D4 Indus XS
    MY2006 D3 Zermatt S Manual
  • Gareth
    Good photos but what's the verdict? Can it still cut it? Did you break it?
  • AndrewS
    Yep its OK just what you would expect, however the cross link valves threw an issue so rock crawl was not as easy as it should be, basically the suspension articulation was impeded on the front end.
    Different but similar electronics in the special programs all improved on the last model.
    The only thing I didn't like was the 'brake grab'.
    Example:- lets say you were being spotted over some rock steps. You get told to stop so you apply the brakes. Then when you are asked to move forward slowly you slowly release the brakes, nothing moves, release a bit more, nothing moves, release a bit more, nothing moves, release a bit more then BAM your off, at this point you have to hit the brakes Mad so slow creep forward from a stand still is difficult. This could be linked to the (3 second brake hold hill start thing) it should disabled when special programs are selected IMO. It could be me not understanding the electronics.
  • Gareth
    Cheers good write up. Looks like you got pretty close to grounding the sills/door bottoms on the rocks!
    That brake feature would annoy the hell out of me! Useful for a learner on hill starts but that's it...
  • Jacko
    Andrew Thank you for sharing. Fantanstic photos. Very inspiring.
  • J77
    Nice photos. Looked like it took everything in its stride.
  • AndrewS
    Please see below a couple of videos.
    For the record yes I could have gone faster and got through first time, I didn't want to as we were trying out different settings/gears. I'm a big believer in finding out what the car cant do before you find out what it can.
    In the first video the 1st attempted climb out was in Grass Gravel, Low 2nd gear, The second attempt was in the same settings but in Low 3rd.
    Yes I was making it hard for the car by coming in at an awkward angle Razz
