      - sportcoupe
      Disco5 front recovery hooks - yes or no?
      I am planning to have rear tow hitch that can double as a recovery point in case I get stuck.
My question is for the front of the Disco5, does it have lower recovery hooks or not? I can't tell by the pictures presented so far. I did not see the option to add front recovery hook either.
      - J77
      Front towing eye behind the front cover, similar place to the D4. Rear one also behind rear the cover.
      - sportcoupe
      - AndrewS
      The rear screw in one is not designed for off road recovery. Rumor has it that they are developing an off road rear recovery as I type this email.
Edit to say screw in one
      - tej
      Seriously !! they are developing now ?
      - Craigp
      Hi tej. The previous post to yours was 2 years ago. You just can't rush something's.
      - IndusD4
      Re: Disco5 front recovery hooks - yes or no?
      sportcoupe wrote:
I am planning to have rear tow hitch that can double as a recovery point in case I get stuck..
Surely you mean the recovery point at the rear is to help someone else that is stuck
      - tej
the fb group says you can use the screw in for off road recovery, whereas the online manual its only for on road towing and recovery
      - AndrewS
      And there is the proof don't believe a thing Facebook says.
