  • Francesco
    Italy
    2017 Discovery Td6 First Edition Farallon Black
    Spare wheel
    Hello to all. I have a Discovery with seven seats. Can anyone tell me how I can check the spare tire pressure? I do not see the valve because the wheel is mounted with the inner side down.
    Thank you.
    Francis Question Censored
    First edition farralon black
  • Blackfly
    I think the spare is fitted with a sensor so it should indicate if there is a problem. Short of that you would need to winch the spare down to a point where you could access the valave
  • Chrismcnaz
    Correct, the user guide states that the spare is monitored as long as you have the TPMS system. Just search TPMS in the guide.
  • Teemo
    And it works - the recent cold weather probably let to a slight drop in the pressure of my spare. I got a dash warning. Spare was installed at factory with valve facing rear of car so it was easy to lower it and pump it up a bit.
    To be clear, I think it only monitors for low pressure - my vehicle information display does not show its actual pressure, but I know from having a puncture last fall that it will tell you "check spare tire pressure!" until you acknowledge the warning. The vehicle is smart though - it immediately recognized that I had swapped the spare and a drive wheel.
    Best to inflate it to rear tire pressure unless you carry a compressor.
  • Blackfly
    this may have been asked in another thread, but will a full size wheel fit in the spare space?
    Yes a full size spare wheel will fit under the space. I had 22 inch full size spare.
  • Blackfly
