I have the Travall dog guard.
Been very pleased with the Travall guards on my last 4 cars - this one is no different.
No - its not heavy.
Two thumb 'screws' at the bottom,
Two thumb 'wheels' at the top.
The one thing I found is that you have to make sure the top screws are correctly seated - if not it rattles a bit.
No - its not heavy.
You are correct about the top screws. They rattled as supplied by Travall
Seems the retaining bolt is over 1 inch too long, and the threaded part is too short, so you
are unable to do them up tight enough to pick up the slack ( run out of thread )
Had to pack mine out with a over size bolt / washer to compensate for the over sized bolt and too little thread
Pretty happy with the results. Added the internal load net to the side and rear divider also plus the Landover rubber matt to secure it all in place
As you can see I have the Landrover loadnet also. Its fine but doesn't cover the full width and as such with 2 dogs that have slobber, the rear seats are getting dirty still. I still want to be able to use the 7 seats occasionally. Has anyone used the Guardsman dog guard vs the Travali one and if so how easy are they to remove and re-fit please?
MY18 HSE in Loire Blue with Dynamic Pack and 22" Dark Grey Aero wheels
I have the "Loadspace partition full height - VPLRS0374" fitted but it rattles at the top. The purple sections are spring loaded into the frame and are loose:
Anyone got any ideas of how to stop the rattle? It would pretty much be a permanent fixture in the car but it might be good to be able to take it out still. We have 2 Retrievers and a Weimaraner pup joining the pack early September.
The rattle is fixed, it is the purple sections in the above post that rattle where they connect to the side of the interior / roof. I used a 3cm section of plastic tubing and wrapped it around the metal, No more rattle! I'll tidy it up replacing the clear tube with some black rubber and cut a bit shorter so it is less obvious,
Does anyone know if the LR half height dog guard or the travail or guardsman ones allow the third row of seats to be deployed while it's in situ?
cheers
I've got the Guardsman (have used Travall guards in the past but thought the Guardsman for the Disco 5 was slightly neater) - I'm very happy with the fit and finish and much cheaper than the LR original
You can position the divider flexibly across the most of the width of the dog guard and you can lower any of the second row with or without either the guard or divider
