The only cars that ADAC could not unlock or start using the relay attack are from Jaguar Land Rover. These cars are the latest versions of the Land Rover Discovery, the Land Rover Range Rover and the Jaguar i-Pace, all of which have been tested by ADAC in the past year.
The keyless fobs for these models use ultra-wide-band (UWB) technology that can very accurately determine the distance between the key and the car, so the car can’t be tricked by the relay attack.
- Labbix
- Labbix
- mordred1973
have to admit, if I don't hear the beep on second press of button, I tend to check on my phone to see if it says locked and alarmed.
- southpawstyles
gavinadams wrote:
I’m the slightly OCD person who like to double press the lock on the keyfob to hear the beep and get the extra security with the double locking
If you use your finger twice on the handle using keyless it will go into double lock mode. Mine beeps to notify as per the double press on the key fob.
