    Incontrol Route Planner - PC
    Is it just me or is this a bit clunky!!
    I was hoping to create my favorites and then sync with the car.
    First attempt was a business address and from the Post Code it not really close to where I want it to be,
    OK, it is close enough as I know the location, but I am a bit OCD and would like it to be spot on.
    With the BMW system, you use the standard Google maps and can pick any spot and then send it to the car.
    For houses I put in the Post Code to the search box and it displays a list and I pick the street, if I add the house number it loses the last digit of the Post Code?
    There appears to be no way of naming them, it just takes the first line of the address, when you go to the car you can then edit it to something meaningful.
    When you come back to the Planner that new name is displayed!!
    Is there anyway of picking a location in the countryside and creating a favorite?
    Jim
