      - Jat
      Deployable Side Steps - positions
      - gavsta
      I certainly don't recall the steps on mine sitting proud of the bodywork.
I'll take some pictures over the weekend.
      - Jat
Thanks.  Someone on a Facebook group confirmed they are out of alignment and that there is a trim part missing that fits at the end of the wheel arch to stop all the crap going between the step and the body.
Will be getting this sorted by the dealership.
Would appreciate any photos to help see what they should look like.
      - gavsta
      It may be worth considering fitting the front mudflaps. I did so, when having the steps installed, as I assumed it would help prolong the life of the actuators.
Coincidentally, there was a car in that day, that was suffering that very issue. The mechanics cleaned up the mechanisms and all was good, but the task is not covered under warranty, so it's either a goodwill gesture, or a bump to the wallet. The parts manager explained they recommend mudflaps when deployable side steps are fitted.
      - Jat
      Thanks - didn't realise the flaps fitted with these steps installed.
      - gavsta
      - gavsta
Maybe yours are the same, after all.
      - Jat
Thanks for sharing these.  Mine are not the same, as they dont run parallel to the car.  The leading edge is almost a little too far out, and the trailing edge too far in.  Yours looks to line up much better to the side/edge of the car body and look neater.
I will look at the front flaps, as the dealer is supplying the missing shields, but I think the larger flaps might be a better idea too.
