  • Taffrican
    Aircon fill port
    Good afternoon gents, the wife’s aircon on the D5 isn’t blowing cold, I bought a refill kit with the 1234 gas but I’m not sure I’ve found the correct port to fill, normally the cap has an L on it to indicate low side, I found 2 ports on the far right side of the engine bay (green caps) the quick fit coupling on the gauges set supplied doesn’t fit either, am I on the right ports? It would be typical of LR to be different to everyone else, is there another port for the Low side?
    Thanks in advance Bow down
    Mike
