  • JST
    FBH?
    does the D5 havea fuel burning heater? if so is it like the D4 one and comes on as required at cold ambient startup or can it be programmed like RRV and RRS?
    No, but you have an option through the app to set the temperature required and start the car remotely..
  • arsi
    Finland
    Cold climate package has Eberspächer Hydronic D5S fitted in a tight space
    under the brace between top suspension mount and firewall
    Click image to enlarge.
    Optionally it can be controlled remotely.
  • Blackfly
    interesting not sure that is available for NAS models
    Is that available in the UK?
  • Blackfly
    I had a quick look and could not see it in the builder. Tried looking up the Finnish site but my language skills are lacking Embarassed
  • arsi
    Finland
    Is it this one: Option 043AV: Remote Park Heat with Timed Climate
  • Blackfly
    cant say I have really needed this but I think if I was in the Yukon or NWT I may be greatful for it. To be honest I am not sure how common they are out here
  • arsi
    Finland
    FBH warms up the engine and with it the interior fast.
    I had FBH in my D3 and when it broke down in winter, you noticed it. With FBH the car heats up within five to ten minutes even in -30C temperatures. Without it, it takes forever (well, longer than my commute).
  • RotherhamPete
    I have the FBH in my Si6. It warms the cabin using the timed climate feature, or it will pre-heat the engine if it's colder than -20, but not both at the same time.
  • Arslanoff
    Czech Republic
    I have an Eberspächer with the optional Remote Park Heat with Timed Climate (works with app also) Strange that it is not a Webasto, I thought they are standart by car manufacturers.
    P.S.: I also have so much loosen adhesive tape in the engine bay. As I have seen it for the first time was like WTF quality car I've bought. Very strange for me.
  • DG
    Re: FBH?
    EDIT <incorrect> some models also have optional timed climate via the touchscreen or via the optional remote Smile
    It is as standard though? Certainly not my HSE, I have the ability to start the engine remotely.
  • DG
    EDIT <incorrect>
  • winger
    Rich - I don't think that's right. You only get one if you order it as an extra or part of a pack now.
