- simonh
ForlornMTL wrote:
simonh wrote:
Good luck. This is what I've always had to do. Maybe the bluetooth profile in the D5 and my previous 2 DiscoSports cause it to work this way ?
You can also (just remembered) in the Phone screen on InControl change the phone setting to only connect for Phone and not Music. Again this seemed to default to both being on again after the ignition was turned off and the phone disconnected. Maybe it's fixed now and will remember the setting??
I can't see the setting for connect to phone or Music. I checked phone settings, bluetooth settings.
I just thought of something, i did not check music settings. Maybe it's there.
Will try after work.
No no no. InControl. Touch screen. Open the Settings (gear icon) and tap All Settings > Features > Phone > Bluetooth Settings > Paired Devices > Tap your phone name > Select Use device for: options.
You have Audio and Phone. Turn off audio. See if that works.
The Settings I mentioned in the previous post relate to the 8” touch screen. The ones in this post are for the 10”. They setup is different because LR are inconsistent in their UI design
- ForlornMTL
- simonh
Excellent news
Good that the setting sticks too. Never used to on my Discovery Sport which was very irritating.
It's a shame there's no proper manual for InControl Touch Pro !
