  • Sacimiddx
    Battery Charging
    Advice please chaps
    whilst upstarting from the D5 i came across this in the manual
    online info as below
    http://www.ownerinfo.landrover.com/documen...c/G1798286
    true ? (surely not ! )
    ctek via the jump terminals ok ?
    thanks in advance Thumbs Up
    I believe the dealers use the terminals to ensure constant battery power when doing software updates. Give your dealer a call and see what they say?
    If you have to remove the battery to charge it, then I wonder why LR give instructions on how to fit a connector to plug in a battery charger so it doesn't need to be removed?
    Battery Charger
    Interesting. I never knew the battery was inside the car right next to a row three passenger and not safe outside the cabin in the engine bay Shocked
  • Blackfly
    The RRS has a similar battery location and strangely enough a sales rep at a well know Montreal LR dealer didn’t know where the battery was either Rolling with laughter
    I like how it is now a conditioner and not a charger
    There are jump ppoints under the bonnet and I fitted the Cteck charging point there it wrks fine
    see here https://disco5.co.uk/forum/thread506.html?highlight=cteck
    But on another note if you trickle charge what is the diffrence between that and the alternator charging the battery when driving along
  • SHARKYSHARKS
    I trickle charge mine through the tow socket like I did on my D3, And D4
  • stiff
    Will soon be fitting a split-charge and aux battery. It must be straightforward as there’s no post of D5’s going bang from those that have already got a dual battery install... So really do wonder why the manual seems to make it so complicated...
    2018MY HSE Si6
    I think LR may be trying to avoid issues with people charging the battery using both +ve and -ve terminals instead of just the +ve and an earth point on the vehicle. By installing that charge point they make sure the earth is on the vehicle. IIRC even in the battery charger manual it states to take the battery out of the vehicle when using both terminals on the battery for charging.
    From the CTEK manual:
    Connect the charger to the battery ́s positive pole and then to the negative pole. For batteries mount-ed inside a vehicle, connect the negative connection to the vehicle chassis remote from the fuel pipe. Then connect the charger to mains supply.
    I have an MXS5.0 test and charge.
  • Nenad
    Why would you fit charger in the vehicle. Second battery I can understand, but charger? I would prefer air compressor there.
    I thought it was only a socket to allow a charger to be plugged in, not the actual charger being fitted to the vehicle.
