  • docf
    Austria
    navigation no voice
    Hello
    Now we have our new Disco 5 HSE Wink
    It is definitely the best car i have ever had.
    But there is one problem.
    The voice guidance does´t work anymore.
    At the beginning everything works fine. But now i can't hear anything from the navigation. ( Yes i know there is a mute button).
    Also the key press sound, which is turned on in the configuration, is muted?
    Is there any way to disable it or set the volume right to hear anything.
    Thanks in advance
    best regards
    Franz
    I had this with mine as well, still doesn’t work when the system is in Dutch, but if I put everything in English than it works...
    You can try to put all in English and than back to German or whatever language you want, and see if it works
  • docf
    Austria
    Thanks for the hint
    i will try it.
  • docf
    Austria
    Thank you very much
    Problem is solved ; )
    I think the female english voice is a little bit sexier than the german female ; )
  • stiff
    Bumping this thread...As just noticed mine is now doing the same. No voice; no key clicks etc.
    Decided to do the reverse and go from English to German, back to English and nothing changes.
    Anyone with other ideas before I head over to the dealer...?
    2018MY HSE Si6
  • docf
    Austria
    i switched it back to english, then shut of the incontrol and closed the doors.
    After ten minutes i went back and tested it successfully in english an could change it to german.
  • stiff
    So numpty award goes to....Me... Rolling Eyes Laughing
    Never realized that the "mute" for navigation is only available when you actually have an active navigation route...Until Saturday night I was still cursing as to why I couldn't find anything in the settings no matter how often I looked or how many menu permutations I tried...
    Oh well...live and learn. Maybe I should read the manual....
    2018MY HSE Si6
    No one likes a quitter. Rolling with laughter
