- docf
navigation no voice
Hello
Now we have our new Disco 5 HSE
It is definitely the best car i have ever had.
But there is one problem.
The voice guidance does´t work anymore.
At the beginning everything works fine. But now i can't hear anything from the navigation. ( Yes i know there is a mute button).
Also the key press sound, which is turned on in the configuration, is muted?
Is there any way to disable it or set the volume right to hear anything.
Thanks in advance
best regards
Franz
- Labbix
I had this with mine as well, still doesn’t work when the system is in Dutch, but if I put everything in English than it works...
- Labbix
You can try to put all in English and than back to German or whatever language you want, and see if it works
- docf
Thanks for the hint
i will try it.
- docf
Thank you very much
Problem is solved ; )
I think the female english voice is a little bit sexier than the german female ; )
- stiff
Bumping this thread...As just noticed mine is now doing the same. No voice; no key clicks etc.
Decided to do the reverse and go from English to German, back to English and nothing changes.
Anyone with other ideas before I head over to the dealer...?
2018MY HSE Si6
- docf
i switched it back to english, then shut of the incontrol and closed the doors.
After ten minutes i went back and tested it successfully in english an could change it to german.
- stiff
So numpty award goes to....Me...
Never realized that the "mute" for navigation is only available when you actually have an active navigation route...Until Saturday night I was still cursing as to why I couldn't find anything in the settings no matter how often I looked or how many menu permutations I tried...
Oh well...live and learn. Maybe I should read the manual....
2018MY HSE Si6
- Craigp
No one likes a quitter.
