  • sanjivsai
    Touch button to access CD and Hidden Storage - NOT WORKING
    Hi All,
    Can anyone help?
    I have a 67 plate discovery 5 and the release button to access the CD and Hidden Storage has failed.
    Does anyone know, how to release it?
    Land Rover Assist have said that I will need to sign a waver that if they damage the unit or anything surrounding it, they cannot be held responsible.
    I would have to pay for any damage and repair.
    I am now really fed up with what appears to be a lemon, had it 9 months and its been in to the dealership about 7 times for various things
    1) mainly Oil Dilution - even though 65% of my driving is long distance over 40 miles and some over 90 miles (one way on a Motorway).
    2) The DEF system (Tank and system replaced) in January
    3) DEF fluid had to be topped up in February
    The intelligent Folding Seats option has not worked for a long time and Land Rover, cannot find a solution.
    Anyone have any ideas as to what they would do in my situation?
    Regards
    Sanjivsai
    The button will likely still work as it’s a simple mechanism that drops the catch (situated centrally on the top edge). While pressing the button use the volume control to pull the flap open.
    This is the only way I can open mine now.
    It’s likely the mechanism that pushes the flap open thats gone weak
  • sanjivsai
    Thank you for your prompt and perfect reply.
    Did you manage to open it ?
  • sanjivsai
    It did indeed work
  • EMcC
    I have an April D5 SE and boy do I miss my CD - like the one I had on my D4 SE.
    I have yet to get round to transferring my CDs to the 'Thingy' that plugs into a socket in the box between the front seats.
  • DiscoStu
    Perhaps one of these might be more useful, tucked in the centre console somewhere? Whistle
    MY19 Silver HSE Lux SDV6
  • EMcC
    Not Quite, but it does remind me of the days when vehicles didn't come with radios.
    The first thing I did was buy an Arial and mount it on the wing feeding the cable under the front passenger seat plugged into a Bush portable radio Wink
    Whenever I approached a pretty looking young lady I reached over and switched it on at full blast with the window open.
    Mind you, in those days that in itself was a major operation, no seat belts so fairly easy to reach over, no electric windows so that was a bit more difficult using the winder !
    Then of course the radios/aerials weren't as good as those of today so the signal would come and go so it was a bit of a gamble whether full volume would work Smile
    Yes, those were the days when external mirrors and locking petrol caps were Extras !!
    Later on the option of a single seat belt was offered, no one ever dreamed of worrying about the passengers !!
  • Chrismcnaz
    Mine fails to open the compartment most of the time, I usually pull on the volume button when pressing the open button which opens it. i have also found that giving it a good hard slam when closing it and then a hard prod of the button when opening it tends to stop it sticking too.
  • DiscoStu
    Mine works perfectly
  • Blackfly
    So does mine, but I do not use it that often
  • Chrismcnaz
    Actually, it might be the fact that the environment is hot at the moment here, maybe the plastics swell up?
