jimbg
You are looking at the settings for USB, you need to select Media Library not USB and look at the settings of that.
Does that make sense? You are going to use the USB to copy from, maybe unplug it until you get to the import screen?
TazDaz
Hi jimbg
thanks for the reply.
Only one problem is that I don't have an icon for Media Library - just Phone, USB, Online media and Radio
I'm assuming this would appear on the "Select Source" window?
jimbg
I have no idea now!!
What is this online thingy?
TazDaz
Oh well, that's not the same as my "select source" screen
Maybe I need some kinda update ?
This is what I see ,,,,
jimbg
maybe, I have had the media library working since I picked up the car in March 2017
TazDaz
OK So thanks for your info - I'll check this with my dealer, see if he knows the answer.
I think the online media is stuff like Deezer or Spotify [which I don't use]
I need to speak to them anyway cos my Easy Entry/Exit doesn't work either.
jimbg
TazDaz
I've already checked out that post from Scrumps - same issue -
1- 5 are OK just no option for 6 onwards
Mine must be a different system Ii reckon
Selecting Online Media just brings up a DRM warning thingy but no extra options
jimbg
I have no idea, does seem weird.
Perhaps it is a 3 litre option!
TazDaz
looks like I might need software phase 4 update:
Software Release Note – InControl Touch Pro
DATE: 06/2018
Page 7 of 14
A concern where the ‘Media Library’ soft key is not available on the Source Selection screen.
This concern results in the customer not being able to access the Media Library.
jimbg
Sounds like a likely cause.
Qwertyd5
I’ve also followed each of the suggestions above and I’m also missing “step 6” onwards!
jimbg
You have no media library either?
TazDaz
nope ..!!
Qwertyd5
