    You are looking at the settings for USB, you need to select Media Library not USB and look at the settings of that.
    Does that make sense? You are going to use the USB to copy from, maybe unplug it until you get to the import screen?
  • TazDaz
    Hi jimbg
    thanks for the reply.
    Only one problem is that I don't have an icon for Media Library - just Phone, USB, Online media and Radio
    I'm assuming this would appear on the "Select Source" window?
    I have no idea now!!
    What is this online thingy?
  • TazDaz
    Oh well, that's not the same as my "select source" screen
    Maybe I need some kinda update ?
    This is what I see ,,,,
    maybe, I have had the media library working since I picked up the car in March 2017
  • TazDaz
    OK So thanks for your info - I'll check this with my dealer, see if he knows the answer.
    I think the online media is stuff like Deezer or Spotify [which I don't use]
    I need to speak to them anyway cos my Easy Entry/Exit doesn't work either.
    https://disco5.co.uk/forum/thread246.html?highlight=import
    It is not your online media by any chance?
  • TazDaz
    I've already checked out that post from Scrumps - same issue -
    1- 5 are OK just no option for 6 onwards
    Mine must be a different system Ii reckon
    Selecting Online Media just brings up a DRM warning thingy but no extra options
    I have no idea, does seem weird.
    Perhaps it is a 3 litre option! Rolling with laughter Mr. Green
  • TazDaz
    looks like I might need software phase 4 update:
    Software Release Note – InControl Touch Pro
    DATE: 06/2018
    Page 7 of 14
    A concern where the ‘Media Library’ soft key is not available on the Source Selection screen.
    This concern results in the customer not being able to access the Media Library.
    Sounds like a likely cause. Thumbs Up
  • Qwertyd5
    I’ve also followed each of the suggestions above and I’m also missing “step 6” onwards!
    You have no media library either?
  • TazDaz
    nope ..!!
  • Qwertyd5
    I don’t have “media library” either.
