  • Coffeecup
    difference in ride and road noise between 19" and 21" wheels
    I'm thinking of replacing my low profile 21" wheels/tyres with 19" to reduce the risk of damage when driving over bumpy ground (potholes etc springs to mind).
    I was wondering if the ride on the 19" tyres will be not as harsh as the on the 21", and possibly whether the road noise might be less too.
    Will be Pirelli Verde on 19" as are on the existing 21" wheels.
    Any thoughts ?
    Laurence
    You might struggle to find some 19" wheels that fit. Apparently D4 19" wheels rub on the brakes so you'd need D5 19" wheels which seem to be a rare option and I've not seen any 2nd hand ones for sale.
  • L90Andy
    2019 Discovery SDV6 HSE Lux Silicon Silver
    The ride will improve due to the larger tyre sidewall between the you and the road.
    FYI, the sidewall height of the 21" is 124mm and the 19" is 153mm, so you'll have 29mm more sidewall.
    Downsides to consider; more flex in sidewall might be felt during cornering and aesthetically they don't look as good. Personal preference of course!
    The tyre on the 19" will be narrower so your road noise point may well be true, but it'll also benefit fuel economy as less frontal area and less drag.
    You'll have to check the 19" fit over your brakes though I suspect they do.
  • Pcheaven
    I had 20’s on my D5,took it everywhere in exmoor, Dartmoor and other car unfriendly places. No issues at all even when rock crawling for extended periods.
    Stock 22’s were terrible.
    Bonus : 20’s are easy to source and cheap, I used new Range Rover ones painted gloss black.
    Edit : side wall on 255/55/20 was 140mm if I recall.
    So, you Brits calculate with inch and mm all together Wink
    Wouldn’t opt neither for the 19, but go for the 20 inch, best of both worlds and easier to find!
  • Coffeecup
    I had thought of going for the 20" wheels, but had felt (rightly or wrongly) that there'd be less risk of popping a tyre if I went for the 19".
    I was thinking that the extra inch might safeguard the rims from being kerbed too.
    Laurence
  • Pcheaven
    20”s are perfect for off road on d5
  • Trevorb1
    19's are the best for ride and they are the quietest for road noise of all the sizes offered, also higher sidewall means less likelyhood of kerbing. 21's are the worst for road noise.
  • SHARKYSHARKS
    I’ve just got some D5 19” which I’ve retread with Good Year Duratrac 255/55/19 😎
    Hopefully find time to swap em over this weekend all ready for winter Thumbs Up
  • harrythespider
    Coffecup I'm actually going the opposite to you. The D5 HSE I've ordered strangely has 19" fitted but I have just purchased a set of 20" . I do actually have a set of 22" but have been told they will be loud and the ride will suffer.
    They're going to be a bit small on a D5. 255/55 is the standard size for 20" wheels. On 19" wheels you'd want 60 profile to get the correct overall diameter
  • Trevorb1
    harrythespider, where are you getting car from, 19's are std on S &SE, HSE comes with 20's as std, wasnt aware you could down spec an hse at build to 19's.
  • harrythespider
    yes, you are correct with the specs,apparently it is an ex management car, started at HSE but with extras to take it beyond Luxury ( except rear screens) and 19's put on for ride quality.
  • SHARKYSHARKS
    JonM I took the tyres off the spare set of D4 wheels I had also had 2 brand new ones so will see how I go hopefully won’t affect the speedo to drastically 🙄
  • Sacimiddx
    Went from 19 to 22
    No significant ride difference - Handlng better if you’ve got your jiggy on
    Did same swap on a ffrr with the same result
    But on a D4 ride compromised as you go up the rim sizes IMHO and pesonal experiance
