- TazDaz
Locking without alarm
I've been advised to 'turn off vehicle alarm' for the duration of the voyage
see
https://www.brittany-ferries.co.uk/faq/tra...ff-onboard
Anyone know how to do this? As far as I know once it's locked the alarm is activated. I'm damned if I'm going to leave it unlocked during the crossing.to Spain !!
- Russell
One push single locking
Opertae the key fob button once locks the doors and leaves the interior alarm turned off. The alarm would still sound if doors, bonnet or boor were openened.
The same can be done by touching the door handle once if you have keyless entry/exit
- simonh
In the vehicle settings menu you can disable the tilt sensor between ignition cycles. IE it’s activated again after you start the car up again. This is still active on a single lock and a ferry in rough seas would still trigger the alarm.
- graemesmith1960
Having done a lot of ferry crossings in Scotland I would advise you get a good handle on how to do this. Nothing more annoying than a boat full of car alarms going off when you've made the mistake of choosing a cheap cabin!
The single press will be fine for short crossings and in the D4 it was also ok for rougher seas. The D5 is a lot more sensitive so disabling the tilt sensor is a must.
2019 Sd6 HSE Corris Grey
- DiscoStu
Agreed, needs to be done via the settings menu
MY19 Silver HSE Lux SDV6
- TazDaz
Found out how to do it now
Use the manual locking method
- simonh
Manual locking method ?
- simonh
Oh emergency locking. Seems a faff and those key hole covers are prone to falling off if messed with too much (or sometimes all of their own accord).
