  • TazDaz
    Locking without alarm
    I've been advised to 'turn off vehicle alarm' for the duration of the voyage
    see https://www.brittany-ferries.co.uk/faq/tra...ff-onboard
    Anyone know how to do this? As far as I know once it's locked the alarm is activated. I'm damned if I'm going to leave it unlocked during the crossing.to Spain !!
    One push single locking
    Opertae the key fob button once locks the doors and leaves the interior alarm turned off. The alarm would still sound if doors, bonnet or boor were openened.
    The same can be done by touching the door handle once if you have keyless entry/exit
    In the vehicle settings menu you can disable the tilt sensor between ignition cycles. IE it’s activated again after you start the car up again. This is still active on a single lock and a ferry in rough seas would still trigger the alarm.
    Re: Locking without alarm
    Also if you have the tracker option this needs to be turned off in the app.
  • graemesmith1960
    Having done a lot of ferry crossings in Scotland I would advise you get a good handle on how to do this. Nothing more annoying than a boat full of car alarms going off when you've made the mistake of choosing a cheap cabin!
    The single press will be fine for short crossings and in the D4 it was also ok for rougher seas. The D5 is a lot more sensitive so disabling the tilt sensor is a must.
    2019 Sd6 HSE Corris Grey
  • DiscoStu
    Agreed, needs to be done via the settings menu
    MY19 Silver HSE Lux SDV6
  • TazDaz
    Found out how to do it now Smile
    Use the manual locking method Thumbs Up
    Manual locking method ?
    Closing it with the actual key. See here.
    Oh emergency locking. Seems a faff and those key hole covers are prone to falling off if messed with too much (or sometimes all of their own accord).
