- Looneyfitter
More issues my17 lux
Thought id start a new thread and just list the issues im noticing already. Anyone else has similar?
Left hand side of the touchscreen works intermittently.
If i play summit via hdmi then the sound it rubbish (firestick)
Had no camera s available a couple times.
Service due (just been done apparently)
Cant alter rear climate via remote control.
Screen can be a little slow to touch.
Keyless unlock and lock works when it likes.
Boot gesture dont work at all or im doing it wrong.
Thats all i can think of for now.
- Chopsy
- simonh
Can you see what version of the InControl Touch Pro you have installed in the D5?
Many of the issue you are seeing I believe are fixed with software updates that have appeared over the last year. Is the D5 brand new or pre-enjoyed ?
Is your Home screen using the old colourful 4 panel interface (Telephone box etc) or the later Phase 4 3 panel 'minimalist' screen (no graphics, just lines and text).
- Looneyfitter
Hey all. Its pre used, 2017. I cant seen to find the software screen but its defiinately 4 screen
Sounds like you are way behind on updates then.
- mordred1973
mine is the 4 tile and only picked it up at end of Sept (2017 HSE) and the lazy dealer of course told me all of the software is up to date!
- simonh
I'd recommend you go to your LR dealer and ask them to update and cite all the issues you are having. It should be covered under a warranty claim. Certainly the rear camera not appearing was fixed with Phase 4.
The service notification may not have been cleared by the dealer if it was serviced. Also it maybe the early service warning bug that was fixed with another software update.
- Looneyfitter
Cheers Gents. Couple questions please.
1 do you have poor sound via hdmi? Mine is horrendous?
Should the rear entertainment be able to see the drivers hdmi input? I cant see it on the rear.
If I plug into the rear hdmi ports the rear entertainment can select either of the rear ports. As such can watch different inputs.
Im sure i read that with the new update they both had to watch the same source.
